Any legally registered MX5 LS V8s in Australia?
- Wombit
Re: Any legally registered MX5 LS V8s in Australia?
There's an LS7 7.0L V8 roadster currently for sale and is fully engineered. Only problem is it isn't a Mazda..
https://www.carsales.com.au/private/details/Ultima-Evolution-2017/SSE-AD-5755249/?Cr=0
This would give you a 2 seater that you can take the top off, have a 710hp V8, and weighing only 980kg wet gives you an acceptable power-to-weight ratio.
- bruce
- Vehicle: NA8 - Turbo
There are a lot better cars for less than $165K. Oops, is that price bashing?!!!!
- StanTheMan
Youre such a basher
Sent from my SM-G935F using Tapatalk
- Rocky
- Concerned Citizen.
Enter the Dragon!
There are a fair few running about https://www.youtube.com/watch?v=1GtUiV6KGJk This is a video of one made by a company called Brintech. I know they build them from time to time.
- bruce
Ta, never seen that before.
A Bullet copy with an LS. Not much MX5 left. Registered in good ol' Qld.
One way to get under capacity, destroked LS
70 240z done!! Well almost.
http://www.viczcar.com/forum/index.php/topic,4438.0.html
- StuwieP
makes you wonder why you wouldn't go with a smaller V8 that liked to rev a bit more.
Aren't the LS motors all pushrod-type?
DOHC, 3l 8,000rpm v8 would be a cracker
My NA6/SE build
Engine #1 RIP 04/07/2020
1uz or 3uz vvti would be under the capacity guidlelines and are an amazing motor but the power isnt amazing, and from what ive read there is hardly any aftermarket.
The engine also has to be out of the same model year or newer car as your putting it into so if your using an NC that makes it pretty hard.
- bruce
StuwieP wrote:makes you wonder why you wouldn't go with a smaller V8 that liked to rev a bit more.
There's dreaming and reality - the LS is realistic.
- StuwieP
I am dreaming. Just throwing thoughts around. If I was going to go V8, I'd be definitely looking at something small capacity.
My reality is an inline 4 and a reasonable sized turbo
My NA6/SE build
- smy0003
The LS is much smaller because is it pushrod. DOCH V8s, even lower capacity ones, are huge and you'd have a pretty awful time getting it to fit.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
- StuwieP
well, you learn new things every day... thanks!
My NA6/SE build
Yeah, pushrod V8s tend to be a bit more compact since the camshaft and lifters are positioned in the empty space of the V
The head just holds the valves and some rockers to open/close them.
Whereas OHC (and especially DOHC) ones the cams need the heads to accomodate the cams, lifters, as well as the valves, and the necessary gears and belts to drive the cams.
Pushrods or no, an LSx loves a rev.
They don't do it for me, but there is a number of reasons why they are the default motor for conversions.
Users browsing this forum: No registered users and 26 guests
