MX5 Colour Code Help
Cal
Postby Cal » Tue Oct 29, 2013 5:02 pm
Does anyone know what type of paint (ie clear over base?) & colour the black section at the very bottom of an NA8 sill is? Mine is stone chipped pretty badly and I'm wanting to clean it up.
emily_mx5
Re: MX5 Colour Code Help
Postby emily_mx5 » Tue Oct 29, 2013 10:09 pm
White Knight Satin black rattle can is near identical, i've painted both black strips and they look a lot better now.
masking tape, primer and paint was all under $20 at local hardware store, and took a couple of hours to do.
well worth it!
davekmoore
Postby davekmoore » Tue Oct 29, 2013 10:46 pm
emily_mx5 wrote:White Knight Satin
Moody Blues song?
Cal
Postby Cal » Wed Oct 30, 2013 9:55 am
emily_mx5 wrote:White Knight Satin black rattle can is near identical, i've painted both black strips and they look a lot better now.
well worth it!
That's the sort of advice I'm looking for, thanks. I have a can of VHT satin black wheel paint I used on a set of Fuchs recently, but I reckon it's a bit flat compared to the MX5 sills. I want to be lazy and blend rather than paint the whole lot. There is virtually no paint behind the front wheels from having stones spraying it off the semi slicks over the years.
Postby Mr Morlock » Thu Oct 31, 2013 12:54 pm
if you go to a auto paint supplier-there must be some in Brissy -they will tell you what to use.
Postby hks_kansei » Thu Oct 31, 2013 4:30 pm
If you were doing the whole lot I'd strongly recommend POR15.
It's a rustproofing paint designed for chassis etc, so it's very resiliant to stonechips and marks.
The only problem is that it's not UV stable apparently (being designed for underneath a car) the label reccomends for areas in the sun that it is coated with some form of clearcoat (not sure if they mean any clear, or a special POR brand clear)
Black_Penguin
Postby Black_Penguin » Thu Oct 31, 2013 6:48 pm
Reading both the US and Australian sites it looks like any clear coat will protect as the don't sell a POR specific clear coat.
tescoking
Postby tescoking » Fri Nov 01, 2013 9:50 pm
try to wrap them with carbon fibre wrap (3M), no need to get carbon style, they have paint black to choose, 3M carbon fibre wrap can take more damage than paint
My 5
