Hey guys I am having a misfire issue. I would appreciate it if anyone in Brisbane would have a spare cam angle sensor I could borrow for a fault finding session and possibly for sale if that's the issue. Any help would be awesome.
Thanks
Angus
Little help in Brisbane!
Feather weight
Re: Little help in Brisbane!
I have a "dodgee" cam angle sensor for the SVT engine. I don't know if it will fit yours or not.
It works fine until it gets hot.
- Regie
- Vehicle: NC - V8
when it starts ti misfire, pour some cold water on the CAS and take it for a drive. That will diagnose if its faulty or not
Thx slyfox I have already organised a loan. Regie might not be CAS as it's also hunting for idle from cold start before it gets hot and sometimes it's a very intermittent misfire. Could also be a sh*t batch of fuel as I filled up before the issue started. I have already changed a coil pack out so pretty sure it's not spark. Leads are ok and plugs are pretty new. Have to start throwing parts at it till I find the issue.
Feather weight
After changing a whole bunch of stuff I'm nearly 100% sure it was a leak in the intake manifold! Problem fixed and ok so far. Thanks for all the help.
Feather weight
Was actually a vacuum leak around an injector. Seal was pinched when fitting the bigger ones for supercharger.
Feather weight
