CoachOz wrote:pie5 wrote:Fixed mine recently.
Nothing a drill, some screws and glue couldn't fix.
If you do it neatly you almost can't tell.
Would you mind sharing the details
Remove the black plastic panel holding the visor.
6 x Torx bolts I think, and a couple of plastic clips.
One of the A Pillar was also unclipped slightly to allow for removal.
Disconnect the interior light cable.
Once removed you will see 1 screw for each visor holding the metal clip which locates the plastic pin which inserts into the visor.
When you remove this you can pull the plastic pin to remove the visor from the panel.
Make sure you note the orientation of the plastic pins as I think they only work correctly one way.
The problem is the visors crack and this allows them to rotate around the pins instead of causing the pins to rotate.
I removed the visor and then drilled 2 small holes through it into the locating pin which I had reinserted into the visors.
And I then put some small self tapping screw through this. One from each side.
I also drilled some small holes to locate some cable ties to assist the process of holding them together.
You will need to remove the screws to locate the visors back in the panel.
Then insert the pin and then the screws through both sides.
I added glue for good measure.
I'll take some photos and upload them.
Hope this helps.
