Dates for the first half of 2006/2007 season.
- Samselectrics
Andrew wrote:The polished Brown Davis roll bars you refer to in the May MX-Tra are not Cams approved
Neither are any of the brown davis roll bars in an MX5 but the clubs will accept them. What they wont accept is those dinky style bars you screw in behind the head rest with tech screws. Yours is fine. They will accept anything that is sturdy and supported diagonally and to the rear. Alluminium and bling bling fairy polished included, though we may have something to say about it. Hahaha.
#35 Someone spent billions building these roads and you have to drive on the grass!
- Boyracer
- MX-5 Encyclopedia
Samselectrics wrote:Andrew wrote:The polished Brown Davis roll bars you refer to in the May MX-Tra are not Cams approved
The steel Brown Davis are CAMS legal as long as you have the 50mm. clearance above the helmet to the top of the cage.
- Matty
Boyracer wrote:Samselectrics wrote:Andrew wrote:The polished Brown Davis roll bars you refer to in the May MX-Tra are not Cams approved
Unfortunately you have to be a dwarf to achieve that. I'm about 50mm above the bar...
