rev dropping/hesitation problem..
vrmmmpshhh
Postby vrmmmpshhh » Sat Jan 27, 2007 8:26 am
hey guys, suddenly my revs will drop to 1000rpm or so while im driving and stay there for a while, then either go back to normal or stall. sometimes the car will seem jerky while cruising too.
i know my battery is old but it never has a problem starting. Maybe its the AFM???
im stumped.
Postby bruce » Sat Jan 27, 2007 10:57 am
leads?
irwin83r
Postby irwin83r » Sat Jan 27, 2007 11:14 am
start cheap
plugs
leads
coil packs (not cheap but i have a spare one if you have an nb8a or alike that you can use to test.)
EDIT: woops... SA is a tad far from NSW guess you wont be using me coil pack :D
Fatty
Postby Fatty » Sat Jan 27, 2007 11:27 am
yeah sounds like leads.
Astroboysoup
Postby Astroboysoup » Sat Jan 27, 2007 4:59 pm
mositure?
i had that problem when a bit of water got in to the engine after cleaning the engine bay.
i warmed the engine up and then removed all the plugs.
plugs 1 and 2 were wet and steam was coming out of the cyclinders.
i let them dry off with the plugs removed. drove around a bit after reinstalling and did the whole process again a few times to make sure all the water had evaporated.
AustCars.net - It's like Facebook but for cars!
neil d
Postby neil d » Sat Jan 27, 2007 5:42 pm
$10 its the leads.
See if you van borrow a set before purchase.
Neil
SP Race Car
RS Clio
ML 300
vrmmmpshhh
Postby vrmmmpshhh » Mon Jan 29, 2007 7:40 am
it seems like i had a loose connection behind the engine. musta happened when i did my extractors and extended the O2 sensor.
also changed my plugs, they didnt look too good...
Astroboysoup
Postby Astroboysoup » Mon Jan 29, 2007 8:53 am
hang on, are you back in adelaide!??
vrmmmpshhh
Postby vrmmmpshhh » Mon Jan 29, 2007 9:01 am
yeah i have been for 4 months now.
