ECU for an SE
blackster
ECU for an SE
Postby blackster » Tue Mar 13, 2007 9:47 pm
Im currently at the stage where some form of piggyback/ECU is required to yield better results out of my SE. I would appreciate some input on narrowing down my choice with an explanation as to why one would think one is more superior over another for the MX5.
Locally available and used on 5s.
Haltec Interceptor/E8
Autronic SM2/SM4
Unichip
Wolf V500
EXEDE
Cheers.
Previous
04' MX5 SE.
02' MX5 Classic ed.
Fatty
Postby Fatty » Tue Mar 13, 2007 9:49 pm
there is also the mania ecu, developed in house by them i think ? maybe add that to your list ? ?
adamjp
Postby adamjp » Tue Mar 13, 2007 10:20 pm
Greddy eManage Ultimate?
Not sure if it will work on the turbo, but I wish my Unichip could be modified by me. A distinct advantage of the eManage IMHO.
Adam
blackster
Postby blackster » Tue Mar 13, 2007 10:33 pm
Fatty wrote:there is also the mania ecu, developed in house by them i think ? maybe add that to your list ? ?
I believe the mania ECU is an autronic.
Previous
04' MX5 SE.
02' MX5 Classic ed.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Tue Mar 13, 2007 10:34 pm
I've got the Haltech Interceptor on the race car with a electronic boost controller....they used my car to set the Interceptor up to run on a SE.
You will probably find that you have to go to bigger injectors as well....I have 550cc on mine.
As far as I know the Mania ECU is a piggy back semi in house design and is set up to run on the SVT engines.
Mr_Q
Postby Mr_Q » Tue Mar 13, 2007 10:56 pm
The Mania ECU is custom work from Walter our friendly ECU guy. :) It's a piggy back and seems pretty effective going by the results. :D
I'll ask tomorrow what kind of gains it provided for the SE.
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
CT
Postby CT » Wed Mar 14, 2007 8:16 pm
My SE is running a Haltech E8 as a standalone with electronic boost control and wideband datalogging. You can also run a wideband with the Haltech interceptor.
The haltech interceptor I think is probably the perfect bang for buck for a road car. :)
blackster
Postby blackster » Thu Mar 15, 2007 12:11 am
CT wrote:My SE is running a Haltech E8 as a standalone with electronic boost control and wideband datalogging. You can also run a wideband with the Haltech interceptor.
I know haltech has tuned boyracer interceptor, is that where you got your E8 tuned as well?
Previous
04' MX5 SE.
02' MX5 Classic ed.
CT
Postby CT » Thu Mar 15, 2007 8:06 pm
Kind of.... My SE is a development car for the E8 so Haltech are doing the setup work. The car will be tuned by my tuner once it's fitted. So, because Haltech have done the development work with Lou and my SE's, you should be able to get a piggy back loom for the interceptor out of haltech without much trouble. :)
