Oh NO! Feeling sick - I broke something expensive
adamjp
Postby adamjp » Thu Jul 03, 2008 7:26 pm
Well, I'm swapping over heads on my car right now. A set of oversize valves have been ordered from the US and will be here soon for the ported head so I'm using the other ported head for a few months.
I just put the camshafts into the swap head - and broke the inlet shaft in half! :cry: That will teach me to juggle a call from work with using a torque wrench. :x
I'm gutted, HKS 264 camshafts are not so easy to come by. :cry: :cry:
In the remote chance that someone has one, or knows of some magic trick that will allow this one to be put back together, please respond. I think it's humpty dumpty - it'll never be back together again.
Adam
AJ
Postby AJ » Thu Jul 03, 2008 7:31 pm
ouch :frown: ........ease up on the weetbix mate :(
XMX5 Rogues
SuperMazdaKart
Postby SuperMazdaKart » Thu Jul 03, 2008 7:41 pm
maybe check this out.
http://www.ozmazda.com/board/index.php?showtopic=7384&st=0&#entry127255
a whole HKS MX-5 racing engine comes up a lot less often then just a HKS cam
adamjp
Postby adamjp » Thu Jul 03, 2008 7:43 pm
I'm not a member there - what price? what spec?
Adam
SuperMazdaKart
Postby SuperMazdaKart » Thu Jul 03, 2008 7:46 pm
heres quoting their sponsore JUSTJDM
[quote name='justjdm' date='Jun 26 2008, 07:31 PM' post='126529']
You won't see this again.
PERIOD...
Basicly works like this....
if you can't drive with a 140hp well 240hp anit going to help.
[font=Comic Sans MS]You have as much chance as seeing a cat take a dump on a frozen lake than seeing one of these again.
[color=#0000ff][color=#ff8c00]Now getting the Mx5 to boogie with the raw sound of an Irish banshee on heat with a serious crack problem easy.............
[/color]
YOU GET
1.6 hard reving bandit
*JUN bottom end
*HKS cams
*HKS gears
*HKS PLugs
*HKS headers
*Quad throttle bodies.
*HKS ECU
NEVER TO BE REPEATED
How much you say?
how about $5495
DROP IN AND GOOD TO GO
Just hope you can steer
[font=Times New Roman]DRIVE HARD
DRIVE HOME
DRIVE HARDER WITH JUSTJDM
[/font]
[/color][/font]
[/quote]
adamjp
Postby adamjp » Thu Jul 03, 2008 7:57 pm
Nice spec - but way beyond my budget. Thanks.
Adam
Postby bruce » Fri Jul 04, 2008 1:33 pm
Ummm, $5000 or a couple of hundred for a new camshaft? Which is cheaper?
SuperMazdaKart
Postby SuperMazdaKart » Fri Jul 04, 2008 1:46 pm
well such an offer doesn't come up often, which is better value?.. take a loan & sell off your current engine/parts if you need to & want to.
i wonder if it's easily drivable in day to day traffic.
Matty
Re: Oh NO! Feeling sick - I broke something expensive
Postby Matty » Fri Jul 04, 2008 2:12 pm
adamjp wrote:In the remote chance that someone has one, or knows of some magic trick that will allow this one to be put back together, please respond. I think it's humpty dumpty - it'll never be back together again.
Could you take it to a cam shop (eg Tighe) and get them to degree it and make a copy?
adamjp
Postby adamjp » Fri Jul 04, 2008 6:04 pm
I have already emailed Tighe.
They can build up a copy using one of my stockies as a blank. But by the time you include postage etc., even they recommend my getting a replacement from the US for less than $100 more.
I liked their forthright advice and wish I was actually going to use them, but I won't be this time around.
I'm not quite so angry at myself today, but I'm still pissed for such a mistake. The problem was a stuck lifter, it was in, but not totally square to the bore. When I torqued down it just jammed more and the cam lobe placed pressure on the shaft.
Lesson - Always lube the lifters and make sure they are IN squarely so they can compress.
Adam
Sheck
Postby Sheck » Sat Jul 05, 2008 10:20 am
highly doubt it. anything built for high revs will be a b**ch to drive around town
Not neccesarily, it depends on the cam specs. I've seen a very drivable sprinter with 310deg cams but small lift that was still idling smooth and quite drivable. He said lift is what makes it 'really' lumpy.
Bad luck with the cams mate, just sold mine last sat too :(
spikey
cams
Postby spikey » Sat Jul 12, 2008 11:35 am
I have got a set of Maruha cams if you are interested $800 for the pair of them.
Steampunk
Postby Steampunk » Thu Jul 17, 2008 11:58 am
HKS
Available to buy individually :wink:
adamjp
Postby adamjp » Fri Jul 18, 2008 8:31 pm
Hmmm... Someone must have contacted him to get one. 8)
With the current exchange rate they as $410 delivered for one. I'm sure you can guess how I know. :D
Adam
