More Turbo Questions
Boags
Postby Boags » Tue Aug 05, 2008 10:13 am
180HP is around 135kw...
Now; let me think if there is a factory MX5 with around 135kw and lots of torque straight out of the box... :?:
mazlot
Postby mazlot » Tue Aug 05, 2008 10:24 am
Ooh, ooh, pick me , I know :lol:
Farken Gruven
MINX
Postby MINX » Tue Aug 05, 2008 10:29 am
Why/how have you come to the figure of 180rwhp?
Have you dríven an SE? or an SP? or a Turbo NA?
Dont know how many killawasps mine has, but simply upgrading the full exhaust including high flow cat made big difference to my bumometer.
"Drivability" is excellent. Easily cruise around in high gears if you feel like being lazy.
SuperMazdaKart
Postby SuperMazdaKart » Tue Aug 05, 2008 12:03 pm
if it's an SE then buying the already designed & made upgrade kits is an easy step.
Garry
Postby Garry » Tue Aug 05, 2008 12:08 pm
That sort of power output is easy to get from an SE. Have a talk to Blackster. Though once you start getting a bit more power you might not be happy with only 135rwkw.
mx52nv
Purple Porsche Eater
Postby mx52nv » Tue Aug 05, 2008 12:57 pm
Garry wrote:That sort of power output is easy to get from an SE. Have a talk to Blackster. Though once you start getting a bit more power you might not be happy with only 135rwkw.
Agreed. Simon over here has 217 rwkw on a stock SE motor & drivetrain for over 2 years now. Of course this is a LOT more than a budget upgrade but the point is that power is addictive :)
Postby Mr Morlock » Tue Aug 05, 2008 1:37 pm
The question was increase the power but retain drivability. More KW always comes with some penalty.
mx52nv
Postby mx52nv » Tue Aug 05, 2008 3:37 pm
Mr Morlock wrote:The question was increase the power but retain drivability. More KW always comes with some penalty.
Best definition of 'drivability' I found from a brief search is
DRIVABILITY
Definition: The general qualitative evaluation of a powertrain's operating qualities, including idle smoothness, cold and hot starting, throttle response, power delivery, and tolerance for altitude changes.
Referenced from here ->clicky.
In the case of Simon's SE (which I was specifically referring to) - the car drives better than before in terms of smoothness & throttle response. Cold start took some time to get right with our temperature ranges from Summer to Winter but I believe it is perfect now. Hot starts were never an issue. Power delivery is better than factory with less lag and more torque/power over the entire rev range (see here for dyno graph). As for tolerances for altitude change or whatever else, Simon has had the current set up and factory drivetrain for 2 years and drove it from SA to Natmeet and back.
Apart from a leaking surge tank (off the shelf SARD item), drivability has been improved dramatically. With access to 19 yrs of MX5 modification knowledge from the world wide community, good parts, a good mechanic and tuner, I believe the only penalty is the hole in the pocket when you go down the path of chasing power in a SE (see here for engine pic).
blackster
Postby blackster » Tue Aug 05, 2008 4:25 pm
Old Fart wrote:Hi Patience please as I know bugger all about Turbocharging.I am thinking about buying a Turbo SE, how do you increase the grunt factor without sacrificing drivability.I would rather improve the factory unit than reinvent the wheel but how.
.I am after about 180 RWHP with plenty of torque and like most I am on a budget.
Your thought please
Steve
Stock SE = 135-139rwhp @ 7 psi
SE + zorst, IC, CAI & +/- BC = 174-181rwhp @ 9-10 psi
Previous
04' MX5 SE.
02' MX5 Classic ed.
SuperMazdaKart
Postby SuperMazdaKart » Tue Aug 05, 2008 5:33 pm
a slang word for exhaust
Richee
Postby Richee » Tue Aug 05, 2008 6:16 pm
Old Fart wrote:Hi Excuse my ignorance, would you mind spelling out what zorst 'etc' means. Thanks Steve
IC = intercooler
CAI = Cold Air Intake
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
Fuzzlet
Postby Fuzzlet » Tue Aug 05, 2008 7:19 pm
My SE with the AEM intake, SPM exhaust and bigger intercooler (not sure of brand though) makes a touch over 130rwkw. Total mods would cost you less than 5k to do (including labour)
