removing lower shift boot HELP!!!!
grump
Postby grump » Sat Sep 06, 2008 6:34 pm
I know i should have a workshop manual, but I haven't as yet, next to get on the list. problem is how do i get the old boot off the gear lever and get the new one on. the diameter of the gear stick is greater than the hole in the middle of the boot. I see there is a pin through the gear lever about half way up , but when i push it it wants to spring back, its only about 1.5mm thick. I don't want to get forcefull and break anything. can anyone help?
marcusus
Postby marcusus » Sat Sep 06, 2008 7:00 pm
When I changed mine, I just cut the damn thing off. I was replacing it, so I figured it wouldn't matter.
Alternatively, miata.net has some info about removing it here. Just scroll down to the section headed by "Removing the Lower Shift Boot to Reuse It". It's almost at the bottom of the page.
Steampunk
Postby Steampunk » Sat Sep 06, 2008 7:49 pm
2 people, 2 flat-head screwdrivers, lots and patience, lots of swearing, and it can be done :mrgreen:
GP14
Postby GP14 » Sat Sep 06, 2008 8:28 pm
1red5 wrote:2 people, 2 flat-head screwdrivers, lots and patience, lots of swearing, and it can be done :mrgreen:
I 2nd that :mrgreen:
JBT
Postby JBT » Sat Sep 06, 2008 9:12 pm
Cut the old one off. The new one slips down over the the gear lever from the threaded end. Yes, it will slide down the lever without splitting but you need to use a smear of lubricant to help it.
Matty
Postby Matty » Sat Sep 06, 2008 10:12 pm
JBT wrote:Cut the old one off. The new one slips down over the the gear lever from the threaded end. Yes, it will slide down the lever without splitting but you need to use a smear of lubricant to help it.
what he said.
SPy vs. SPy
Postby SPy vs. SPy » Sat Sep 06, 2008 10:31 pm
what he said.
Ditto, and exactly what I said to do in the latest Club Mag :D
grump
Postby grump » Sun Sep 07, 2008 5:21 am
thanks guys, I didn't try getting the old one off as i just took one look and went, what the!!!! so i'll venture out to the work shop a bit later after i've had a couple of mugs full of patience
oongie
Postby oongie » Wed Sep 10, 2008 10:51 am
x2 on the swearing, lube and patience
90 NA6 98RWKW of fury 1.7L fury box
