Well it seems my current heads decided to break at a weld and have also developed another crack.
What do people recommend to replace my current headers with?
The current ones look like tuned length 4 to 1 headers. They were on the car when it came from japan.
NA6 Headers
- corners
- Vehicle: ND - Supercharged
NA6 Headers
- Steampunk
NA6 Headers
If money is not an object, then in my opinion, C.E.S. near Beenleigh are as good as it gets.
If you are on a budget, then just get yours re-welded/reinforced or put up an EOI on the for sale/WTB section.
Perhaps Genie makes a set?
If you want a custom set, then I can recommend Lee's Exhaust, but they are over at Springwood, so it's not all that easy for you to get to.
Opinions are divided between 4-2-1 vs 4-1 systems, so just go with what you have and what you are used to.
- corners
NA6 Headers
The guy I have taken the car too has recommened a hurricane 4 to 2 to 1 system
Will give CES a call.
I believe the headers are beyond repair.
NA6 Headers
I've used those on ebay from a guy in Perth. Had them for 20 thou and no problems. They were cheap enough to spend extra on getting them ceramic coated. Price is up a bit now.
NB SE, NA 1.8.
- corners
NA6 Headers
trader wrote:I've used those on ebay from a guy in Perth. Had them for 20 thou and no problems. They were cheap enough to spend extra on getting them ceramic coated. Price is up a bit now.
The hurricanes or the CES racing ones?
NA6 Headers
Dont know - they didn't have a name but same supplier that's on there now. I did other mods at the same time so cant tell you the power gain.
NB SE, NA 1.8.
Users browsing this forum: Google [Bot] and 14 guests
