Beatrush 'Brass' Gear Selector Bush ??
mx5 brass bush for gear shifter
- Regie
- Vehicle: NC - V8
lets get another group buy happening. my one is goone
- sliq
gather more interest and i'll be happy to set one up
- madboy
sliq wrote:gather more interest and i'll be happy to set one up
what are the benifits and how much are they lilkely to be? Will it help smooth out my chunky 2-3 gear change?
sorry about going off topic...
- sliq
madboy wrote:sliq wrote:gather more interest and i'll be happy to set one up
from the sounds of things, that doesn't sound like a bush problem. i think your 2nd gear synchro could be rooted
- Fuzzlet
sliq wrote:from the sounds of things, that doesn't sound like a bush problem. i think your 2nd gear synchro could be rootedbasically, if you have problems putting the car into gear e.g. selecting the reverse gear and the gear does not select, that ought to be the gear selector bush.
My reverse does this....car only has 35k kms on it.....it did it when I bought it with 22k on it aswel...
- sliq
Fuzzlet wrote:My reverse does this....car only has 35k kms on it.....it did it when I bought it with 22k on it aswel...
mine did too. had to put the car in first, roll it forward a bit, then reselect reverse
- Fuzzlet
Yep exactly what I have to do...sounds like it may be a common fault then...
