Postby The Pupat » Thu Jul 06, 2006 12:40 pm
glen73 wrote:The Pupat wrote::shock:
I reckon you'll be needing that clutch, the standard 1.6 (it is a 1.6 isn't it?) one barely hold the stock power output.
are you refering to na or turbo. either way 100's of people that have used the greddy kit in the states havent changed there clutch on the stock output of the turbo if thats what your refering too? i think the td04 runs betwwen 7-9 pound stock. im not really following what you mean
The Pupat wrote:Might be worth swapping to the 1.8L clutch and flywheel whilst you are at it also.
if i was going to go 1.8 then wouldnt i be better off do it fully ie aftermarket as wouldnt the 1.8 clutch cave in aswell?
the greddy kit in the states doesnt make mention of changing the clutch.
i think alot of things comes down to the driver
if i was to drive it like i stole then yep, the stock clutch wouldnt last 1 day.
Missed this post.
I've never researched the greddy kit but I would have a feeling most owners do it on the cheap so I wouldn't surprise me if they are making do the stock when it really isn't up the task. Also I reckon you would be putting out significantly more since you got all the extra bits to make the power (spark control, fuel control et al).
By 1.8L clutch what I meant was swap to a 1.8L flywheel which allows you to run a larger diameter clutch and therefore a higher load rating without requiring 747 to crash on the clutch pedal to move it.
But you can always try the suck it and see approach... you'll only wreak a clutch that you won't want anyway so no great loss.
