not coil packs!!
Sean
Postby Sean » Sun Sep 24, 2006 10:53 pm
Craig wrote:Your not stupid, those plugs should last for ages as you said! :?
Glad I refused them at my last service, prefer the normal jobbies that get turfed and renewed more often! 8)
Yes he is :lol:
He bought the fancy plugs to start with :mrgreen:
I've never found any magic in spark plugs, as long as they are the right heat range, gapped appropriately and in good condition they will work fine, no matter what brand or fancy hype they carry.
I've seen cars make over 500hp on $3.50 NGK plugs after taking out $20 fancy (won't say the name) plugs that gave no more power or economy.
StanTheMan
Postby StanTheMan » Sun Sep 24, 2006 10:56 pm
fark....thats gotta hurt. But look .... I'm sure we can all be acused of doing something stupid, where commonsense just wasn't around. or had decided to go on a few weeks leave.
I hope your Coil pack finds a home where its needed.
I'm with Craig. I swap spark plugs every 5k km with the oil & filter.
Sean
Postby Sean » Sun Sep 24, 2006 10:59 pm
StanTheMan wrote:I'm sure we can all be acused of doing something stupid, where commonsense just wasn't around. or had decided to go on a few weeks leave.
Mine's still on leave, if anyone finds it, can you shoot it back my way?
Sean
Craig
Postby Craig » Sun Sep 24, 2006 10:59 pm
Sean wrote:Yes he is :lol:
Well now you mention it, he did buy an Evo Gold! :lol:
*runs and hides in Canberra for the week* :P
AJ
Postby AJ » Sun Sep 24, 2006 11:05 pm
one thing i've learnt & lived by over the years & it works well...........check the simple solutions FIRST, it can save you a lot of $$$ & heartache
:mrgreen:
XMX5 Rogues
Postby Okibi » Sun Sep 24, 2006 11:38 pm
Check your PCV valve from your cam cover to the top of your intake plenum is working.
If its stuffed it will try and suck air in from the cam cover and that will foul the plugs.
If that doesnt work, borrow someones AFM and see if that fixes things.
irwin83r
Postby irwin83r » Mon Sep 25, 2006 7:06 pm
well.....
i dont know if this makes me a bigger idiot or less an idiot... BUT i was right it wasnt the plugs :P AND wrong.. they wernt burnt out.. iridium's have a odd shapped electrode to start with
car was missing as normal at wake field.. only got 2 outtings before it started to show and in the third outing was just plain unberrable.... very frustrating.
Gilly. i dont have an ERG pipe :shock: :lol: but! it is fairly warm back there.. might be worth a shot.
Okibi. that PCV valve just a one way valve?? or it an electronicly regulated thingy??
JBT
Postby JBT » Mon Sep 25, 2006 7:17 pm
Have you changed the plug leads as well as the plugs?
irwin83r
Postby irwin83r » Mon Sep 25, 2006 7:19 pm
JBT wrote:Have you changed the plug leads as well as the plugs?
nah just tested with voultmeter... they arnt that old and are apparently good quality..... but hell ive been wrong before :P
might buy some new ones tomorrow and give mania a call about the CAS..
Postby Okibi » Mon Sep 25, 2006 7:56 pm
irwin83r wrote:..Okibi. that PCV valve just a one way valve?? or it an electronicly regulated thingy??
one way
JBT
Postby JBT » Mon Sep 25, 2006 8:53 pm
PCV valve explanation here
The plug leads and plugs should really be changed every 20,000 - 30,000 km. The MX-5 is hard on these things because it uses a wasted spark system i.e. two leads/plugs fire at the same time. This is twice the rate of most engines which only fire one plug and lead for the cylinder on compression.
The car runs like cr@p when the leads start breaking down under load. Anyway, a new set won't be wasted if they don't fix it because you will eventually use them.
Craig
Postby Craig » Mon Sep 25, 2006 8:54 pm
Maybe it's really wanting to tell you it's not Evo Gold, but Camel instead, and it's giving you a humpy ride! :mrgreen: :lol: :P
irwin83r
Postby irwin83r » Tue Sep 26, 2006 6:17 pm
Craig wrote:Maybe it's really wanting to tell you it's not Evo Gold, but Camel instead, and it's giving you a humpy ride! :mrgreen: :lol: :P
you might of hit the nail on the head there craig...
after all if it goes like poop its half way to a camel :P
had no time to do anything today :? as far as buying leads or calling mania.
long shot... but anyone in the southern sydney/wollongong area with an NB8A that can help me test afew things??
as someone here mentioned swap AFM and/or plug leads momentarily to see if problem goes?
irwin83r
Postby irwin83r » Tue Sep 26, 2006 6:21 pm
wait a tick...
iv the PCV valve works on vacume.. what happens when you turbo your car and make the pressure in you intake manifold greater than that off your crank case??
Russellb
RIP Nov 2014
Postby Russellb » Tue Sep 26, 2006 7:03 pm
irwin83r wrote:wait a tick...
Pressure Pushes it Closed I still run the STD PCV on my car
My ClubmanRebuild
MX5 SE Rally car is HERE :)
