Cheap CAI
GP
Postby GP » Fri Jun 08, 2007 1:02 pm
Does the air come from the cabin? If so doesn't it make the cabin stink of petrol and your ears ring from the induction noise?
Graham
Richee
Postby Richee » Fri Jun 08, 2007 1:25 pm
GP wrote:Does the air come from the cabin? If so doesn't it make the cabin stink of petrol and your ears ring from the induction noise?
No it dont, the hole in the "firewall" exits above the cabin but below the windscreen. there is some plastic stuff covering the area above the exit point.
Your can still hear the induction though :mrgreen:
Mazda Tribute - its a boat
Juffa
Postby Juffa » Fri Jun 08, 2007 1:28 pm
It is getting the air from the same place as the Loch Stewart, Mania and most other CAIs, and that is the area above the firewall and below/in front of the windscreen. The cabin does get it's air from that area, however I am not aware of anyone reporting fumes in the cabin because of this?
J
GP
Postby GP » Fri Jun 08, 2007 3:14 pm
Cool, Does a hole have to be cut in the firewall?
Graham
Juffa
Postby Juffa » Fri Jun 08, 2007 3:25 pm
GP wrote:Cool, Does a hole have to be cut in the firewall?
Yes, a hole is required.
GP
Postby GP » Wed Jun 13, 2007 2:55 pm
Another dumb question :roll:
Is it just a matter of relocating the windscreen washer bottle? Going to do this mod as I notice the performance drop off when it gets hot.
Graham
Fatty
Postby Fatty » Wed Jun 13, 2007 3:10 pm
yep you need to move the bottle, that's all. everything else can stay where it is. and then just drill a big hole! be very careful with the positiioning of the hole tho.
GP
Postby GP » Mon Jun 18, 2007 10:41 am
Been doing a bit of research and came across this which is probably old news to all of you but new to me :lol: http://autospeed.drive.com.au/cms/article.html?&A=0892
As Jules said leaving the airbox in would seem to be a waste of time after doing all the other work.
What are peoples thoughts on the \"Simota Super Power \" filter that's mentioned, They have them at Mania for $75.
Graham
GP
Postby GP » Mon Jun 18, 2007 4:13 pm
The Simota Heat Sheild Filter Is already sealed and I was wondering what peoples thoughts on this filter are.
The air will never be cold but the air under the bonnet is a lot hotter than in front of the windscreen so I think this is a great mod.
He also mentions a larger AFM off a 86-88 RX7, Are these available? Very Expensive?
Graham
Matty
Postby Matty » Mon Jun 18, 2007 4:54 pm
Steve 818 wrote:
GP wrote:He also mentions a larger AFM off a 86-88 RX7, Are these available? Very Expensive?
You could probably pick one up from a wreckers but I'm pretty sure that Matt didn't end up using the bigger AFM as he couldn't get a happy compromise with that setup.
Now that the Jaycar DFA is available though, you could probably get that setup working well but it will involve more money and some tuning.
What he said. Just get a programmable MAP-based ECU and be done with it.
GP
Postby GP » Mon Jun 18, 2007 5:01 pm
:shock: WTF is that. Something tells me that it's not an aircleaner
If it hasn't got carbs and points I don't know what it is :D
Graham
Grumpy
Postby Grumpy » Tue Jun 19, 2007 12:21 am
And my $2 bit of pipe with it's restrictive bend lets cold air into the air box which suits me just fine, untill I blow the engine up and have to do a rebuild or transplant.
Sadly MX5 less for a while.
Rebuilding an 89 Honda CRX
Boags
Postby Boags » Tue Jun 19, 2007 9:42 am
He is suggesting you buy a replacement ECU which will allow you to tune via a MAP (Manifold Absolute Pressure) Sensor. These take a pressure reading and RPM and add fuel. They DON'T use an AFM (air flow meter - what you have now) which is quite restrictive to airflow.
Hence the comment about turning a $2 mod into a $1500+ project.
Boags
GP
Postby GP » Tue Jun 19, 2007 10:42 am
Amazing how things get out of control and all I wanted to know was whether the Simota filter was any good.
I think I will get filter from mania and get rid of the airbox and let everyone know whether it's worthwhile :D
Graham
ampz
Postby ampz » Tue Jun 19, 2007 8:11 pm
Would you still need the afm adaptor plate with the Simota filter?
If so factor in another $20 on top of the filter price.
Huh?
Users browsing this forum: Google [Bot] and 17 guests
