Custom camshafts: Who has serious ones?
Steampunk
Postby Steampunk » Tue Mar 04, 2008 8:51 am
OH!
Yes GC, the specs were from Integral and I was considering getting them as they were the best value and seemed to know what they were doing.
Hamish, thanks for the warning mate! I won't get them until probably the last half of the year, I'll send GC a PM pointing out what you stated.
Where are you getting yours from by the way? PM me if you wanna keep it secret :wink:
Steampunk
Postby Steampunk » Tue Mar 04, 2008 8:54 am
DAMN CT! That is some serious Mumbo!
123kW @ wheels equates to around 170kW @ flywheel :shock:
hamish71
Postby hamish71 » Tue Mar 04, 2008 9:45 am
Nope, its not a secret....the fact is noone has convinced me yet that they actually know what they are talking about when it comes to cams for the VCT engine.
Tighe have a great reputation for cams, but my queries ended with a response much like the once mentioned earlier in this thread. Something like:
\" send money and existing cams, we will weld them, and send them back\"
I have found a competition engine builder in QLD (CT knows who I am talking about) who has really impressed me both with his knowledge and attitude, but by his own admission, he doesnt have much experience with VCT. He also only does competition motors currently.
There are a number of threads on the \"big\" forum, discussing Maruha cams, which apparently were designed by/in cooperation with tomei...but there is bugger all evidence available as to their success. Having said that, for me, I am leaning that way, but they are expensive, and require an expensive lifter kit. But, for the NA, or non VCT engines, their appears to be a much wider selection. At the end of the day though, cams dont make power on their own. You need to spend on headwork, intake, exhaust, and then use cams, and probably an aftermarket ecu to maximise the hp gain from the newly available air.
Matty
Postby Matty » Tue Mar 04, 2008 12:17 pm
hamish71 wrote:Nope, its not a secret....the fact is noone has convinced me yet that they actually know what they are talking about when it comes to cams for the VCT engine.
Not surprising really when the work involved is so huge as to be prohibitive to anyone except an OEM. You'd have to make a full fuel and ignition map for every variation of cam timing, which if you have two independent cams is a massive exercise. Even with only one variable cam it's a lot of work. And there isn't a big enough market for MX-5 cams to justify it.
You could do some groundwork with software (eg Engine Analyser Pro) but it's still a massive undertaking.
If anyone ever did though, it would be fantastic. You could have near-race-tuned top end and a decent idle and torque curve.
There's the next problem. You can design one cam as above, but what about the next customer who has a high-compression motor and bigger headers? Throw the old data out the window...
irwin83r
Postby irwin83r » Thu Mar 06, 2008 7:37 pm
i cant remeber who it was but someone got some cams supplied and fitted in melb for 900-1000 bucks.. was almost a year ago ill have a look for the old thread
Steampunk
Postby Steampunk » Thu Mar 06, 2008 7:42 pm
I would appreciate that Irwin.
I remember when I was doing the rounds via telephone and email, I didn't find anyone who showed any kind of interest in our cars.
Tried Tighe, Crane, Crow, Camtech a couple more I can't remember.
I guess they just don't understand that a car doesn't have to make >200kW to be exciting.
irwin83r
Postby irwin83r » Thu Mar 06, 2008 8:01 pm
1red5 wrote:I would appreciate that Irwin.
problem is they are all businessmen and well there just isnt that much business in 5's
Russellb
RIP Nov 2014
Postby Russellb » Thu Mar 06, 2008 9:37 pm
$1000 is not Uncommon. My New Blanks Reground to Turbo performance was that. and there bigger than the Tighe 803c and cant wait to get my new engine running. These were from Waggott and he asked all the Right Questions, Like Comp ratio , RPM range , street or track work, Turbo or NA . and he didnt even want my OLD cams .
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Rob E
Postby Rob E » Fri Mar 07, 2008 7:24 am
Crow do billets, no problems.....they have a couple of grinds for MX5s. Guy last year made 5rwkw on a pair. They arent overly expensive.
Steampunk
Postby Steampunk » Fri Mar 07, 2008 11:41 am
Hmmm... he must have spoken to someone more friendly. I would want more than 5rwkw for $1000 give or take.
The front runner is still Integral Cams from the US @ $625USD for Stage 3 or 4
ben wilson
Postby ben wilson » Fri Mar 07, 2008 6:54 pm
Bear in mind when comparing different profiles that some makers give total (advertised) duration and other give duration at 0.050\" lift. They will be a very different number which can make it confusing to compare them.
Rob E
Postby Rob E » Fri Mar 07, 2008 11:16 pm
1red5 wrote:Hmmm... he must have spoken to someone more friendly. I would want more than 5rwkw for $1000 give or take.
Just need to know what you want. I spoke to Crow last year too, from memory about 650 for a pair of billets for the B6. Ended up going with Maruha cams though.
Steampunk
Postby Steampunk » Fri Mar 07, 2008 11:31 pm
Well for $650 I will definitely go Crow Cams.
I will contact them soon.
Tighe wanted $500 to weld my stock ones. :evil:
Thanks Rob.
Fatty
Postby Fatty » Sat Mar 08, 2008 12:10 am
fartfreddygassit has some tighe cams in his 1.8 that he seems pretty happy with. tighe have a pretty good rep in the mx5 community i thought.
Rob E
Postby Rob E » Sat Mar 08, 2008 8:06 am
I know of one forum member who seriously dissuaded me from Tighe due to major problems with them - seems the lobes on his starting breaking up after 10,000klms or so.... This was enough for me to give them the miss.
What will the car be used for?
Is it s daily driver?
Users browsing this forum: No registered users and 17 guests
