gearbox and differential oil
- Steampunk
Garry wrote:Get quality pump bottle with a metal hooked end, I recon its a lot easier than trying to use a hose and funnel.
I dont
Not all of us is as strong with The Force as you.
Steve, whatever lubricant your buy, please buy a decent one. Don't skimp on a few bucks.
- Garry
I can assure you that there is a lot more of The Force associated with pumping almost 2L of oil into a gearbox with a squeeze pump than there is pooring oil into a funnel and letting it drain down a bit of pipe and into the gearbox. I've tried both methods and found the hose and funnel much easier, quicker and cheaper.
But, hey, if you like to spend all day pumping then feel free to pump away.
- CT
wun911 wrote:Advantage of havin 6spd box is you dont need a hose or pump you can fill it from the shift turret.
But he still needs a pump for the diff...
Except you still need to have the top fill plug open so you can tell when the box is full
- PASHN8
CT, what oils do you run in the your box and diff?
Redline lightweight shockproof for the box?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
- Patty
Agree with Garry. I just changed my gear oil yesterday, ran a hose through the engine bay and funnel at the mouth. Except I used radiator hose. Redline MTL is good but much (much) dearer than $12.50/L. A breaker bar is also a good idea for avoiding misfortunes..
There's also a washer on the drain plug but I don't know if you need to replace that at every change like the sump plug.
Grace Green NB8A
- Patty
stevesports wrote:hmm...this is getting a little annoying now. It seems i will need 3 quarts for the gearbox and 2 quarts for the diff. Is that right? or do i need less?
Don't really know what a quart is but roughly 2L for gearbox and 1L for diff. Basically, if you have more you can save it for next time (edit: just read what wun wrote). If you have less, you won't be doing yourself any favours.
Grace Green NB8A
no they dont remove the shifter to replace gear box oil.
But on the bright side you can do it yourself its really really easy.
Take the centre console off (about 5-6 screws in total).
remove the shifter and replace the rubber boots.
There is a real good write up on it at miata net.
http://www.miata.net/garage/shiftboot.html
every ounce counts
