Carbon Fibre Intake Manifold anyone?
CT
Postby CT » Fri Feb 06, 2009 9:48 am
graemebc wrote:Best thing to do if you wanted to run quads would be to source the manifold etc from japan.
The difference with a turbo would probably not be great as you say, but that would also depend on the plenum shape.
I intend to go quads with a 99 head on my 1.8 with some mild cams. 140 rwh is quite doable with decent headers and exhaust. Those levels will keep me very happy with not much loss of drivability. After I fiddle with runner lengths to try and keep as much as low end torque as possible.
Why Japan? I've had 3 different styles custom made here - around $600 per piece or companies like EFI Hardware will take a stock manifold, remove the mounting flange and make you a manifold for a similar price. Buy local if you can - especially in these times.
Cam choice is quite important with quads as is air speed into the head. For a road car, smaller butterflies and runners help airspeed to stay up maintaining torque and power in a usable range. Talk to guys that do it all the time but for a pretty stock roady, 40-42mm throttles would be sensible. I used to have 48mm in the racer with 120+rwkw to give you an idea. There are websites around with the calcs for helping you to work out ideal butterfly size and CFM requirements - worth a google.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Feb 06, 2009 8:00 pm
begi is currently doing some r&d on a new manifold atm. however nice this is I think I may be going with the begi unit as I cant afford to develop my own and this is clearly not going to be what I am after for a single throttle body application. there is quite a large thread here on the begi unit
http://www.miataturbo.net/forum/t27089-new/
They are testing 4 different kinds from what I have read.
I will be purchasing the info that the good Woo has obtained when I rebuild my motor (if he lets me of course) so I can get a proper flowing head to match. I will also probably speak to tighe to get the correct cams and head internals to match all of this. Probably very expensive but I will have a very large amount of air to flow so I would rather not be dissapointed and spend twice if you know what I mean.
tbro
Postby tbro » Sat Feb 07, 2009 10:45 pm
Bloody hell,
I can see I've got a lot of reading up to do on ITB's etc, if I'm going to refit the set back on scooter!!!
Me thinks too many years on trucks.
Terry
