Jackson Racing CAI
madboy
Jackson Racing CAI
Postby madboy » Tue Jun 02, 2009 6:40 pm
93_Clubman wrote:
madboy wrote:I wonder how it would perform with the AFM removed, I am thinking about buying a MSPNP with the IAT sensor and removing the AFM.
If you've not already seen the following then it might be worth a look:
viewtopic.php?f=29&t=34991
Essentially, the MSPNP is a considerable spend if you're only seeking to improve air flow by removing the slightly restrictive NA6 AFM. Replacing it with a S4 or S5 RX7 AFM & transplanting the MX5 AFM internals to it would be more economical. However, if you want & will use the headroom the MSPNP will give you to do other things then that's a different story.
Yeah, I have plans, but they will take some time to come to fruition, one step at a time, a MSPNP is one of those steps.
A good CAI where I don't have to cut holes or make up elaborate heat shields works for me. I won't see track time so the air diverter over the radiator is not so essential for me, If cooling does become an issue, then another step will most likely be an alloy radiator.
MB
Jackson Racing CAI
Postby 93_Clubman » Wed Jun 03, 2009 1:34 am
madboy wrote:A good CAI where I don't have to cut holes or make up elaborate heat shields works for me. I won't see track time so the air diverter over the radiator is not so essential for me, If cooling does become an issue, then another step will most likely be an alloy radiator.
Sounds like you need a ducted headlight cover &/ or TSI.
corners
Vehicle: ND - Supercharged
Jackson Racing CAI
Postby corners » Wed Jun 03, 2009 1:24 pm
I have a ducted headlight cover and keep getting water in the headlight so I have removed it for the moment.
Jackson Racing CAI
Postby 93_Clubman » Wed Jun 03, 2009 2:41 pm
jcs86 wrote:I have a ducted headlight cover and keep getting water in the headlight so I have removed it for the moment.
:shock: thanks - hadn't heard of that happening.
mx52nv
Purple Porsche Eater
Jackson Racing CAI
Postby mx52nv » Thu Jun 04, 2009 1:20 am
Hmmm...I wonder if it is more to do with the headlight not being sealed correctly or rubber seals are gone rather than due to the headlight intake cover...? I have had my headlight intake covers for close to 10 years without water going into the headlights. 8)
Les @ MX5 Shop
corners
Jackson Racing CAI
Postby corners » Thu Jun 04, 2009 11:35 am
mx52nv wrote:Hmmm...I wonder if it is more to do with the headlight not being sealed correctly or rubber seals are gone rather than due to the headlight intake cover...? I have had my headlight intake covers for close to 10 years without water going into the headlights. 8)
Les @ MX5 Shop
I think its cause the vent is directly above the bulb when closed.
Should there be a rubber seal as from memory there is none...
jerrah
Jackson Racing CAI
Postby jerrah » Thu Jul 16, 2009 1:23 am
I've also wondered about buying a JR CAI due to the questions of the legality of pod filters in Australia.
Is there much in the way of aftermarket airboxes for the NA except for the Jackson Racing one?
1991 MX5
Jackson Racing CAI
Postby 93_Clubman » Fri Jul 17, 2009 1:00 pm
jerrah wrote:I've also wondered about buying a JR CAI due to the questions of the legality of pod filters in Australia.
i don't think the JR CAI featured in this thread falls into the category of exposed pod filter, which i believe potentially can present a legal problem
jerrah wrote:Is there much in the way of aftermarket airboxes for the NA except for the Jackson Racing one?
http://www.miata.net/products/intex/
jerrah
Jackson Racing CAI
Postby jerrah » Fri Jul 17, 2009 2:58 pm
I didn't mean the JR CAI was an exposed air filter. My car came (2nd hand) with a pod filter.
1991 MX5
Jackson Racing CAI
Postby Jeo » Fri Jul 17, 2009 4:11 pm
Any airbox that exits at roughly the right spot can be made to fit without too much effort. I've currently got one out of a V8 VN Commodore in my NA. Also have a bigger/better flowing V8 VS unit sitting there, just waiting for a little motivation on my part before it goes in.
