Jaycar Digital Air Fuel Display and GReddy eManage
timk
Postby timk » Mon Jan 29, 2007 11:11 pm
I hope you get a board discount for fixing his site! :lol:
As for working you too hard, I'll let you on my yacht every now and then to make up for it! :P
Boags
Postby Boags » Wed Jan 31, 2007 11:17 pm
A small update on the air/fuel display.
I have found that the temp of the engine doesn't effect whether the O2 sensor will work. I can idle the car up to temp and have it sit for a while and the sensor won't work. But when I drive to work in the morning it is working by the end of my street - about a minute at 2-3000rpm.
Going to make one of these for the race car now! :mrgreen: I love it.
Boags
PS - SAB???? Still no pics?!?!?!?! :cry:
Sean
Postby Sean » Wed Jan 31, 2007 11:45 pm
Boags'MX5 wrote:A small update on the air/fuel display.
Boags
I've seen some issues with AFR sensors while tuning that may explain what you're seeing here.
What I found was that at idle (and low air speeds in part of the exhaust system where the sensor is located) there is not enough exhaust gas passing over the sensor to keep it warm or give it an accurate reading.
On a sensor with heating wire, this can often be overcome by running a better heater wire to the sensor, or moving the sensor into a more direct area of exhaust gas flow.
Basically with decreased airflow, the engien temp is irrelevant as the exhaust gas cannot effectively heat the sensor to it's accurate range of operation.
Sean
Boags
Postby Boags » Thu Feb 01, 2007 1:10 pm
:D That makes perfect sense to me, and reflects my findings! Thanks sean.
Where the phooq is SAB???
sabretooth
Postby sabretooth » Sun Feb 04, 2007 12:45 pm
:o
A miracle has happened! I downloaded the photos from my CF card!
:o!!!
You can barely see the display, but that's supposed to be a pic of the eManage software.
He's really looking at Geoff's pants. Really.
\"And this spaghetti of wiring over here is...\"
AFR!
Boags deciphering the eManage Engrish?
\"Thanks MTV, and thanks Xzibit for pimping my ride!\"
Astroboysoup
Postby Astroboysoup » Sun Feb 04, 2007 5:48 pm
you kents
you beat me to the pics posting stage
im haivng a few problems calibrating the fuel meter
I've set VR1 to the desired dim level for the photo sensetive resitor BUT
vr2 for the zero calibration ain't workin..
I solderd the 1.8kohm resistor in the corret space but altering the vr2 doesn't do anything..!
little help?
AustCars.net - It's like Facebook but for cars!
