Ohhh my GOD!! Megasquirt goodness...
- timk
- sabretooth
- Vehicle: NA8 - Turbo
ben wilson wrote:sabretooth wrote:My only concern is tuning. My car isn't exactly stock, so I'd have limited use for the included base map. Anyone know of any QLD tuners that know how to work one?
A mate of mine took his MS injected car to the local dyno and the operator raved about how easy it was to tune...
I wish i had gone to this place to get in tuned......tuner i used had no idea.
- Sean
Rob E wrote:ben wilson wrote:sabretooth wrote:My only concern is tuning. My car isn't exactly stock, so I'd have limited use for the included base map. Anyone know of any QLD tuners that know how to work one?
Commom problem with tuning - I feel for you Rob.
Is it worth posting here to help others avoid making the same mistake?
Most competant tuners can get good resuls from anything, but I'd prefer to go to someone who spacialises in my chosen ECU (no matter what ECU that is). That way you are more liekly to get full use of all available functions on the ECU.
I've heard people complain about the cost of going to certain reputable tuners, but really, is an extra few hundred dollars saved in tuning really worth it? A good tune will probably save you the few hundred dollars in fuel bill over a short period of time.
It's also a nice bit ofinsurance for all the money you've spent on building up the car and engine. No good savng a few hundred dollars if it's going to cost you an engine and retune later.
I'd be looking to someone who has runs on the board, and lots of happy (tuning) customers - Having a wideband and or dyno doesn't make you an effective tuner. There are more than a few memeers here who have kissed engines goodbye in the hand of so called "experienced" tuners.
- zoomzoom
- Vehicle: NA6 - Turbo
Just thought I would put up a brief update, I have the MSPNP in and working. It seems to be working quite well, I have got a bit of a tune on it just by doing logs and letting the logviewer make corrections to the target air fuel ratio.
The car is just as drivable as before and I LOVE the launch control
Next thing to do is fit some sort of air filter as the origional piping doesn't match up to the nb inlet manifold I fitted to gain a variable tps, which I also want to connect up in the future.
As a note, I can not speak highly enough of diyautotune for they're service and advice. I ordered the wideband one weekend and it arrived only a week later on the monday.
Tim
Tim
