Craig
- Vehicle: Non MX-5
Postby Craig » Mon Dec 17, 2007 7:42 pm
*** Audi Q5 55 Sportback - HYBRID! Zero -100 in 5.3 seconds!
AJ
Postby AJ » Mon Dec 17, 2007 7:44 pm
you are SO predictable craig................i lost a bet with myself tho, i thought it would take at least 30 seconds for you to follow food
Don't worry about what people think, they don't do it very oftenXMX5 Rogues
Craig
- Vehicle: Non MX-5
Postby Craig » Mon Dec 17, 2007 7:46 pm
Agro
Postby Agro » Mon Dec 17, 2007 7:48 pm
I learnt from the BEST.....my MUMMY! She's awesome
How would I know, I'm only a puppet!
chris d
Postby chris d » Mon Dec 17, 2007 10:12 pm
My friend had a 2002 Passat with exactly the same problem which took VW at Orange two weeks and $2000 odd dollars of his money trying to find the problem.
In the end they found out that the air intake was getting clogged and not allowing enough air in to the engine. They had to spray some sort of spray into the intake and were reccommended to do it every year.
Hope you fix it soon.
Chris
1993 Clubman. Style Bar. Tow Bar. Racing Beat chassis brace.
Craig
- Vehicle: Non MX-5
Postby Craig » Mon Dec 17, 2007 11:51 pm
StanTheMan
Postby StanTheMan » Tue Dec 18, 2007 7:32 am
are those stuffed wine leaves????
Wog food is the best.
I'll prolly chase you down today Agro.....
StanTheMan
Postby StanTheMan » Tue Dec 18, 2007 11:46 am
OK so my pump is for a B6 after all. Presumably the Tank assembly for the pump might be different to the NB8B's but maybe not. Can anyone confirm or deny this?
If the tank assembly is different what about the pump itself?
cheers
StanTheMan
Postby StanTheMan » Tue Dec 18, 2007 12:14 pm
StanTheMan wrote: Bear in mind for $230 you can get a brand new high powered one for your turbo application at Mania.
Correction:
$275
Walbro High Output Fuel Pump
Andrew
Postby Andrew » Tue Dec 18, 2007 4:47 pm
StanTheMan wrote:OK so my pump is for a B6 after all. Presumably the Tank assembly for the pump might be different to the NB8B's but maybe not. Can anyone confirm or deny this?
cheers
NFI about and NB8B pump but this is what an NB8A one looks like -
sabretooth
- Vehicle: NA8 - Turbo
Postby sabretooth » Tue Dec 18, 2007 5:16 pm
Agro wrote:StanTheMan wrote:you work at a dealership. You have mechanics there. You probably have a whole warehouse full of spare parts. You are a Wog with charm.......what gives Agro? Get these kids to fix your car!!!
I've had it at the work shop for 3 days in total, and they recon they have tried all these test and can't locate the problem.
I am frustrated and angry that my car keeps letting me down and no one at work can pick what's wrong! (speculate)
You guys on the forum seem able to diagnose what's going on and give me things to try to work it out............
Thanks for the offer Stefan, but I do not have internet access and have only just read the forum.......
I will keep plodding along and see when the bugger totally packs it up. My concern is it packs up in peak hour traffic with a semi up my ar$e or even over the Xmas break when no one is available to fix the darn thing!
My money is still on a dodgy coil, or the CAS.
Have they tried testing it when it's actually broken down or are they only able to test it when it works fine? The intermittent problems are the worst ones.
Agro
Postby Agro » Tue Dec 18, 2007 8:42 pm
sabretooth wrote:Have they tried testing it when it's actually broken down or are they only able to test it when it works fine? The intermittent problems are the worst ones.
It has happened on my way home from work, 3 times and all 3 times really hot days.
By the next morning when I drop it off at work's service centre it's ok.... not playing up.....sigh!
bigdog
- King of the kennel
Postby bigdog » Tue Dec 18, 2007 8:48 pm
Simple... don't go to work. Problem solved.
Marvin - '02 Silver SP - BD, PSS9, Guru, Build #62
Cardomain
Agro
Postby Agro » Tue Dec 18, 2007 8:49 pm
StanTheMan wrote:are those stuffed wine leaves????
Yes, my mums stuffed vine leaves are the best!
Thanks for your call today, may come around Thursday after work if time permits, just to be on the safe side.....will call you!
Agro
Postby Agro » Tue Dec 18, 2007 8:50 pm
bigdog wrote:Simple... don't go to work. Problem solved.
I would love to do that!
(makes note to ones self to find a rich husband)
