Aftermarket Headers NB
RG.net
Postby RG.net » Thu Jan 22, 2009 11:39 pm
sliq wrote:i'm afraid mxhevn, that all sarcasm is lost on the internet :cry:
well thats what the eye rolls are for, if people dont get that then god help them!
RG.net
Postby RG.net » Thu Jan 22, 2009 11:42 pm
philz wrote:Is anyone running with no muffler?
ie/ still has cat and resonator, but from the axle back they either run another resonator or straight pipe.
take the stock muffler off and take it for a drive, its very VERY loud after 3000rpm, and with the roof up the fumes will intoxicate you.
wun911
Postby wun911 » Fri Jan 23, 2009 12:08 am
ohhh you can run without a muffler?
I know its friggin heavy its like 9.55 kg (stock NB8B)
Are you allowed on track without one (easily removed like the seat)
So I want to dyno the following and do a write up:
1 without muffler
2 with n power muffler
3 with stock muffler
4 AC on
5 AC off
every ounce counts
philz
Wheel guru
Postby philz » Fri Jan 23, 2009 12:46 am
Ive run it without a muffler, and yes its loud, but sexual, also backfires when you let of the accelerator, hardly legal though.
I reckon the exhaust without a muffler is too straight, as it exits straight from the resonator, if you add those 2 90 degree bends similar to the original exhaust without the muffler in the middle, it should quieten it down a TAD, if not resonate it.
Might try it, probably cost <$200 with no resonator.
Postby sliq » Fri Jan 23, 2009 9:52 am
without the muffler it sounds like an early 1990's lawnmower.
