They probably needed to use up some old stock after the 323 went out of production.
Casey: Which begs the question - wouldn't it have been cheaper to build up a SP replica like Brian and Pilsner from a wreck/cheap import NB8B rather then build an SP replica from a SE?
Casey wrote:Which begs the question - wouldn't it have been cheaper to build up a SP replica like Brian and Pilsner from a wreck/cheap import NB8B rather then build an SP replica from a SE?
Whereas there's a number of proven ECU/piggyback/interceptor options available to you for the SE at very reasonable purchase prices and are easily tuned all because it doesn't have S-VT.
Garry wrote:Rumour has it the SE engine is based on the engine from one of the 323 turbo motors with tougher crank shaft and connecting rods or bigger bearings or some such. Which explains it's lack of SVT, lower compression and lower redline. It's not the same engine as a regular MX5.
Russellb wrote:Casey . Batman's B6 has oil sprayer as a standed and so does Greenmachine's engine from the Open heart Surgey on both engines I would say they all doO and Pilsners engine has them too
I hope when my engine come apart I find them in there too![]()
Do you reconise this Casey?
GRRRRR
Users browsing this forum: Google [Bot] and 3 guests
