Help - Intermediate Starting Problem
hi all,
my fd's 1.6 NA import has a funny starting problem. sometimes the car start right up but sometimes the car takes longer cranking to start. it happens to both cold and warm start. once the car starts, it goes strong.
we have changed a lot of stuff like spark plugs, leads, tuned idle, changed timing, swapped ECU etc and to our knowledge the only thing left uninspected is the fuel pump.
anyone has any idea??? did we miss anything?
thanks in advance.
Philip
thanks in advance.
Philip
- Bevan
- Bevan
Sorry, just re-read your post. It's actually cranking, so I very much doubt it's the starter. If you haven't checked the fuel pump, that might be it. How long does he leave the key in the 'on' postion before trying to start? Maybe the fuel pump hasn't fully primed itself and is trying to do so while he's actually trying to start? Leaving the key in the 'on' position for longer would help if this is the problem.Philip Lee wrote:good point starting motor... not sure if we looked at it but there is definitely enough juice from the battery.
I doubt the fuel pump would be perform badly of be blocked somewhere if it's runnign strong once started...
Bevan wrote:Sorry, just re-read your post. It's actually cranking, so I very much doubt it's the starter. If you haven't checked the fuel pump, that might be it. How long does he leave the key in the 'on' postion before trying to start? Maybe the fuel pump hasn't fully primed itself and is trying to do so while he's actually trying to start? Leaving the key in the 'on' position for longer would help if this is the problem.
mmm, we might just try that. the reason we didn't inspect the fuel pump was that the car runs fine after starting so that shouldn't really be a problem.
and we really run out of idea....
- Bevan
- Craig
- Vehicle: Non MX-5
Craig wrote:Perhaps a sticky injector?Maybe run some cleaner through it...once you get it started that is!
do u mean those stuff that u put into your fuel tank?
Craig wrote:Try swapping the ignition barrel/switch too, others have reported intermittant problems with them.
ignition barrel as in the thingy that u put your key in?
sorry for the ignorance.
thanks
Craig wrote:Yes and yes!
i see thanks.
with the ign barrel, if we change that does that mean we need to use a different key? this may sound stupid as i'm not familar with that parts.
No, behind the key barrel is a switch that the key turns.
You could spend an hour with a mates MX-5 and borrow theirs to see if that fixes things then put it back in.
But since the problem doesn't happen all the time it may no the issue.
(i'll try and find a photo of the switch from my NB)
Okibi wrote:..(i'll try and find a photo of the switch from my NB)
I had no luck, but theres' a photo here
http://www.mx5parts.co.uk/product_info.php/products_id/975
