NA 1.6 Stock ECU with turbo
Posted: Mon Aug 14, 2006 8:48 pm
by bark
I am planning on installing the B6T engine (I will be swapping over the coil packs from the MX5) but would like to know if I can use the stock MX5 (B6) ECU to run the B6T engine?
Posted: Mon Aug 14, 2006 9:41 pm
by bark
Steve re stock ECU, basically it relates back to state requirements. As long as I use a stock ECU from the engine then the local authorities will pass it. So my options are:
a) use B6T engine with B6T ECU, but this can't handle the coil packs from the MX5 from what I read unless someone knows how to convert the signals over to be readable??
b) turbo the B6 engine and use the B6 ECU
c) any other options people can think of??
I want the car to be approved with a turbo but need to work with the parameters set.
Posted: Mon Aug 14, 2006 9:45 pm
by kitkat
install an aftermarket ECU but leave the olriginal one in there so it *looks* as though there is a stock ecu installed.
Posted: Mon Aug 14, 2006 9:50 pm
by bark
Our local road authorities will see through that I think, they are pretty thorough in their checks...
Posted: Mon Aug 14, 2006 10:00 pm
by kitkat
bark wrote:Our local road authorities will see through that I think, they are pretty thorough in their checks...
im sure it would be possible... just have to find a good place to hide the aftermarket ECU.... i dont really think they will pull the car apart to make sure its all stock.
have you thought about an aftermarket chip? i dont know if its possible but it might be worth checking out.
Posted: Mon Aug 14, 2006 10:12 pm
by bark
Has anyone got any pic's of their installed aftermarket ECU's?
I haven't researched aftermarket chips for a B6 to run a turbo. Anyone got any thoughts or links on this?
Posted: Tue Aug 15, 2006 11:55 am
by glen73
basically you can put your aftermarket ecu anywhere you want.
you can leave your factory one there all plugged in just have the loom chopped.
only problem is if the inspector knows his sh*t.
Posted: Tue Aug 15, 2006 7:57 pm
by Russellb
Just Gut the STD Ecu And put an after market Comp inside the STD box
Posted: Fri Aug 18, 2006 9:38 pm
by bark
Russellb I like your thinking!
Anyone know if any aftermarket ECU's will fit into the Std ECU box?
Posted: Fri Aug 18, 2006 10:29 pm
by glen73
i know a microtech will. i haven't physically seen the others though.
