Replaced the injectors next with 460 rx7 units and that took about 20 mins.
mossy wrote:I put in a walbro 190 high pressure unit today, what a biatch of a job, the walbro is longer than the standard unit so the bracket wouldn't go on the bottom which meant cutting the outlet pipe so i could bend the centre bracket downwards to get the bottom bracket on. I then bought a fuel line hose and attached it where i cut the pipe and ran it down to where the outlet pipe finished.
Replaced the injectors next with 460 rx7 units and that took about 20 mins.Motec is next on the agenda for next weekend so hopefully it all works!!
