timing belt Question
Posted: Sun Aug 27, 2006 10:49 pm
by Astroboysoup
Is there suppose to be any slackness in the timing belt whenyou put it back on
i don't remember how it was when it was on before...
there is a little bit of play at the top between the two cam gears.. about 5mm of movement
and about the same between the tensioner pullys and the crank....
Posted: Sun Aug 27, 2006 11:10 pm
by SuperMazdaKart
should easily be able to look it up in the mazda servicing manual you got that you copied for me. i printed the while thing for the NA6 at work :) double sided pages & hole punched into a black folder.
Posted: Sun Aug 27, 2006 11:20 pm
by Astroboysoup
if only i could find my copy
Posted: Mon Aug 28, 2006 12:01 am
by SuperMazdaKart
want another copy? 8)
