Mods?
green_comet
Car Detailing Guru
Postby green_comet » Wed Aug 30, 2006 3:54 pm
Just get a Apexi SafcII not expensive.. and adjust your and and fuel with it..
Should be able to get a few more kW from your car.
glen73
Postby glen73 » Wed Aug 30, 2006 7:08 pm
mine hasn't missed a beat. 126rwkw @ 5psi.
still a very reliable ride but then again i cant see why it wouldn't be reliable with more boost.
the 1.6's are great motors combined with a proper tune.
get a standalone ecu so then later if you want turbo you already have the ecu.
Matty
Postby Matty » Wed Aug 30, 2006 8:48 pm
The ECU controls the fuel injection and ignition timing, which (along with the air flow) is what generates power. The factory ECU is tuned conservatively for a worst case setup (eg bad fuel, worn parts, blocked injectors, etc). So an ECU that can be tuned for your exact engine and premium fuel should net a bit more power.
Plus it lets you delete the air flow meter, which increases air flow and gets a little more power. But without airflow-increasing mods, it'll never be a massive gain.
An ECU is also a good \"building block\" mod - ie, from there you can do many other mods that otherwise wouldn't work with the factory ECU (eg cams, turbos, etc).
It's certainly not necessary to start with though, the intake and exhaust will unleash a few kW and run perfectly well (and totally reliably).
irwin83r
Postby irwin83r » Fri Sep 01, 2006 9:02 pm
i done full exhaust (extractors, high flow cat, rez, muff :lol: ) and a clod side CAI and only gained around 10rwkw on my nb8a
just to give you an idea.
you can more or less go any turbo kit and have it reliable, IF you stick to low boost.
but they do say boost is addictive :roll:
