Project: Rebuild!
sabretooth
Project: Rebuild!
Postby sabretooth » Mon Sep 11, 2006 12:09 pm
Due to the slight derailment of the other thread, I'll start a new one - I'm going to log my engine rebuild here, complete with pictures. It should give people a good idea as to what goes into the build of an engine and also serve as a diary of work I've done.
Lindsay at UMR just called me back. They've checked all of hte engine parts I gave them out, and...
Crankshaft:
Needs to be ground to the next undersize and therefore will require differently-sized rod bearings compared to normal.
Block:
No problems. Will be bored out to the next oversize.
Head:
No problems. They do want to check valve guide clearances with a few valves though, and so I'll bring a couple in. I kept the intake valves, used two exhaust valves in the Familia engine, and I think I may have binned the rest. We'll see.
Rods:
They'll balance the rods no worries - as one of the rods \"unusually\" had a bit more meat than the others. He also forgot the shotpeen and polish ($180), but I made sure that it'll get done.
Other:
ACL mains and piston bearings, thrust bearings, 9 welsh plugs ($208.68 ). Those prices are cheaper than what I've seen elsewhere, so I'll probably go with UMR for those parts. I'm also calling Performance Wholesale today to see if they can get me some ARP head and mains studs.
Total cost thus far for the engine work is $1180. :o A bit more than I was expecting to be honest - I was thinking $1000 tops. I'll publish an itemised receipt once I've received it - I'll be getting the engine back with all work done this week - and when I get that and my mains bolts I'll be able to put it all together!
sabretooth
Postby sabretooth » Sat Sep 16, 2006 1:58 am
Hot diggity. I have my parts back! Photos and stuff to come later, but the bill for the bearings, valves, machining, balancing, shotpeening, shims, lightening, honing, etc etc etc came to $2k :shock:
So yeah - pics and stuff to come later! :D
And thanks Daz, will do!
sabretooth
Postby sabretooth » Sun Sep 17, 2006 11:44 am
Here's the cost breakdown:
  • Block: Acid dip - $50
  • Block: Bore & hone 4 cylinder block - $110
  • Block: Surface grind 4 cylinder block - $50
  • Block: Supply and fit welch plugs - $18
  • Crankshaft: Grind 4 cylinder crankshaft all over - $125
  • Conrods: Close and hone 4 rods - $100
  • Conrods: Pin fit and align 4 rods - $112
  • Conrods: Shot peen - $163.64
  • Head: Surface grind - $45.46
  • Head: Machine and no couple up 16 valves - $200
  • Head: Remove and replace valve guide - $192
  • Misc: Balance engine components - $220
  • Parts: ACL conrod bearing set - $50.41
  • Parts: ACL main bearing set - $88.41
  • Parts: ACL thrust bearing set - $18.35
  • Parts: Small end bush - $60
  • Parts: Exhaust valve - $112
  • Parts: Valve guide - $96
So there you go. Parts totalled $425. Replacement of the valve guides was a big chunk of cash, as was the component balancing.
The valve guides were unexpected - apparently there was a bit of play in one/some of them, meaning that the valve could shift in the guide and allow oil through. I didn't want that so I asked them to go ahead with the guide replacement. There was no better time really.
I gave them my intake valves, and they supplied 8 new exhaust valves - I had lunched two of them in the engine originally, used a further two for the Familia engine and only had 4 left - and they looked pretty marginal. So I ditched them. I suppose more could have been saved, but they were cheap in comparison, and it's a moot point now. It was the cost of 4 valves vs 8 valves.
I'm going to be doing a lot of reading over the next few days. The plans are to get everything I need to know about the engine. Then I'll check the ring gap, fit the rings to the pistons and check the orientation of the rods and pistons to make sure that I get them in the right way. Then I'll assemble the pistons.
Then, I'll get some studs/bolts, maybe another sump and do some clearance checking. Then comes the final wash, some coating with oil/CRC - and then assembly!
jules
Guitar Hero
Postby jules » Mon Sep 18, 2006 10:21 am
Excellent work Sabre. Make sure you don't snap one of the piston rings during fitment. I have seen it done!
Jules
sabretooth
Postby sabretooth » Mon Sep 18, 2006 7:22 pm
OK, here are some more photos. I have so many pretty much for documentational purposes.
Image Image Image
- the block itself. The shop fitted the welch plugs for me, and to be honest I'm glad they did. They'd be a right pain in the arse if you stuffed them up and accidentally belted one into the water jacket. The plugs appear to have some sealant around them - it looks a lot like permatex instagasket.
The rear of the block.
Image Image
The front.
With the basic photos done, it was time to put the engine onto a stand. I remove the head piece from the stand and started attaching it to the block:
Image Image
And mounted:
Image Image
I used 12mm x 1.5 bolts. Only 3 of the 4 holes threaded - they seem to hold nicely, but I've got a 4th sitting there loose just in case. Anyway, with that mounted, I had more flexibility with my photos:
Image Image
Closeup of the cylinders - you can see the machining work quite nicely here.
The underside:
Image Image
sabretooth
Image Image
The (important) attached tag, and how the engine sits now - ie, wrapped in plastic!
Now, for the other parts. The crank was largely unexciting. It had to be ground to the next undersize - not that you can tell, really.
Image Image Image
Image Image
The rods - they've been shotpeened, although I wouldn't have a clue how to tell. Some shimming was also done to the rods because of play somewhere in them. Damned if I know where.
Image Image
Image Image
And finally, the head - I don't have any pics of it out of plastic as it was wrapped when they brought it out of the back of the shop. I'll unwrap it when I'm ready to assemble it all, though.
Image Image
Image Image
sabretooth
Postby sabretooth » Mon Sep 18, 2006 7:33 pm
Also, to compare and contrast - here are the before photos:
Image Image Image Image
JBT
Postby JBT » Mon Sep 18, 2006 9:12 pm
That newly reconditioned stuff looks beyoooodiful Mr Tooth. :) Makes one feel that it should be assembled using white gloves.
kitkat
Postby kitkat » Mon Sep 18, 2006 9:56 pm
very nice sabre.... ill bring ya the lifters on the weekend as well... but they are still in the head. Ill prob just bring it as a whole for ya.
sabretooth
Postby sabretooth » Mon Sep 18, 2006 10:47 pm
Thanks, lads! :D
OMY005
Postby OMY005 » Mon Sep 18, 2006 11:10 pm
sabretooth wrote:Then I'll check the ring gap
What gap are you going to use? It it needs to be opened up how are you going to do this?
Just curious because a had a bad run with two sets of pistons and rings in a motor bike engine that I built years ago because of conflicting info on the ring gap.
Andrew. :)
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
OMY005
Postby OMY005 » Mon Sep 18, 2006 11:25 pm
:?: Linished rods usually look like this with the flashing removed from the side. And shot peening usually looks smother.
Just curious again.
Andrew. :)
sabretooth
Postby sabretooth » Mon Sep 18, 2006 11:38 pm
What's linishing?
I haven't researched what sort of gap to use yet.
I also have no idea what to have expected the shotpeening to look like (hence the closeup) - so it's good to see one possibility...
edit: oh, linishing is removing the mark down the body. Hmmmm... I did ask for a polishing - goddamn. I wasn't charged for it though. Nothing to stop me getting it done now I suppose...
Boags
Postby Boags » Tue Sep 19, 2006 10:52 am
sabretooth wrote:Nothing to stop me getting it done now I suppose...
$$$??? :shock:
Matty
Postby Matty » Tue Sep 19, 2006 12:20 pm
Sabre, what are you doing for hardware?
ie:
Head bolts/studs?
Flywheel bolts?
Rod bolts?
Main bearing bolts/studs?
cheers, love the pics. I'll archive this thread when you're done.
