Gearbox about to die?!?!
deez
Postby deez » Sat Jan 06, 2007 12:54 am
It's been happening for about a month now. Every once in a while I'm double clutching, or downshifting quickly, there's a sharp, loud, and scary crunching coming from the gearbox :shock: This happens even when I had the clutch fully depressed, and seems to happen more often on the 4-3 downshift. More so than the 5-4 although I have had that happen before as well :frown:
Any ideas? Is the gearbox about to..... DIE?
89 Eunos Roadster
Sheck
Postby Sheck » Sat Jan 06, 2007 8:03 am
Why are you double clutching? You may have muffed the sequence. other wise i'd say it is syncros.
See if the sound still happens if you just single clutch and change gears really slow. It should be better or if your syncros are completely shagged then you'll be able to hear that about 15-30 teeth on the gear skip making a disgusting sound and then finnaly it engauges with a crunch.
Check the oil for any metal.
Hope that helps a little as i'm out of ideas :D both of my previous stuffed gearboxes whined like they were in reverse which meant that the gears were worn/stuffed.
Dave
timk
Postby timk » Sat Jan 06, 2007 9:19 am
I hope this isn't off topic but I try to double clutch around a downshift blip whenever possible just to make the synchros and gearbox last longer. It's just interesting that you questioned it, do you think it has a negative impact of some sort?
AJ
Postby AJ » Sat Jan 06, 2007 9:40 am
sab, double clutching is just a waste of time with modern gearboxes, all you're doing is wearing your clutch components out prematurely by doing it mate :)
XMX5 Rogues
Inf3ct0R
Postby Inf3ct0R » Sat Jan 06, 2007 9:54 am
sab. my clutch hose leaked because i heel/toe and double clutched too much, i think! LOL
timk
Postby timk » Sat Jan 06, 2007 10:53 am
So it's better to let the synchros spin up the input shaft?
zoomzoom
Postby zoomzoom » Sat Jan 06, 2007 11:00 am
As far as I understood double clutching with a bit of a hit of the throttle to match revs should both match the speed of the engine, input shaft and mainshaft to the speed of the output shaft to take some stress off the syncros, and also prevents a compression lockup. This should all be taking from the stress on the car, and the extra wear on clutch would be very minimal if at all as it is not under load at the time, and is not having to take the load of getting the engine speed up to the output speed.
AJ
Postby AJ » Sat Jan 06, 2007 11:10 am
saboteur wrote:So it's better to let the synchros spin up the input shaft?
a simple blip on the throttle while downshifting is sufficient, rev matching is as old as time itself........however, double clutching is only necessary in a gearbox that has no syncromesh.......ie: getting a three on the tree EH holden back into low gear whilst still moving.......most truck gearboxes in the old days were crash boxes, so double clutch with a rev match throttle blip was the ONLY way to change gears, but even that has gone by the wayside, most modern trucks have syncromesh g/boxes, usually with air assistance.....once again, in a modern car, double declutching is just a wasted effort, it doesn't do anything but wear out components from overuse :)
XMX5 Rogues
zoomzoom
Postby zoomzoom » Sat Jan 06, 2007 11:28 am
the throttle blip will only match the engine speed to the output but still leaves the synchros and clutch to spin up the main and input shafts. I still dont see how double clutching is going to prematurely wear components, if anything it should be making them last longer
zoomzoom
Postby zoomzoom » Sat Jan 06, 2007 11:36 am
I do think it really isn't necessary for normal road driving though.
deez
Postby deez » Sat Jan 06, 2007 1:26 pm
Sorry guys I may have misused the terminology. By double clutching I don't mean *really* double clutching. All I'm doing is blipping the throttle between the downshift :P
89 Eunos Roadster
EGG80X
Postby EGG80X » Sat Jan 06, 2007 7:58 pm
deez wrote:Sorry guys I may have misused the terminology. By double clutching I don't mean *really* double clutching. All I'm doing is blipping the throttle between the downshift :P
heel and toe
JBT
Postby JBT » Sat Jan 06, 2007 8:44 pm
EGG80X wrote:heel and toe
Only applies if your "toe" is on the brakes and you use your "heel" to blip the thottle at the same time.
JBT
Postby JBT » Sat Jan 06, 2007 8:49 pm
zoomzoom wrote:the throttle blip will only match the engine speed to the output but still leaves the synchros and clutch to spin up the main and input shafts. I still dont see how double clutching is going to prematurely wear components, if anything it should be making them last longer
Rev matching on downshift will absolutely reduce clutch, transmission and drivetrain wear and strain.
Double de-clutching will prematurely wear the clutch hydraulics because you're making two clutch operations when only one is needed.
Mick93
Postby Mick93 » Sun Jan 07, 2007 2:46 pm
AJ is wrong if you are blipping the throttle on a doulble declutch it wont wear things out as long as it is done properly. The Blip should be done whilst the gearbox is in Neutral then clutch and put back in gear. If you do it whilst just having the clutch in you are wearing out the clutch. And I am sorry AJ but you are very wrong about syncro boxes. Porsche used them for 15 years at Lemans before they moved to paddleshift gearboxes. They still double declutch though to keep the the car in gear at the correct rpms. You could never be quick on the track if you could not do it and if done correctly you should not wear your syncros. However like anything it is practice that gets it right and it dose take time to do it correctly. Its up to you wether you think the skill is worth aquiring.
Good Luck
