Posted: Mon Jan 15, 2007 11:00 pm
When the engine is cold... eg off in garage over night. The fans will/should not come on when you start the car. The fans should turn on when the engine reaches operating temperature. Therefore when turning the car off after a drive and returning it to it 5mins later the fans will turn on straight away (because the car is still warm).
The a/c fan will only even turn on when the a/c is on.
The a/c fan is on the drivers side.
If the fan is coming on before the engine is warm it may be a good idea to inspect the wiring, it may have been rewired to turn on straight away. The noise may also be a busted fan. Dissconnect the plug to the fan and see if the noise is still there.
This wiring diagram may come in handy....
