I said 8 PSI for the following reasons...
6 PSI will get you to SE power levels, however, you'll already have to replace the clutch so you might as well go higher until you reach the limits of other things.
At 8 PSI, treated very carefully and with a bit of luck you can get away with a 1.6 LSD. Obviously if you are unlucky or thrash it you are going to brake the 1.6, so it's up to you... You will need heavy duty clutch (or clutch from an NB) You have the fuel and control to go well higher than that though.
At 10 PSI you will blow your diff to hell if you do something silly one day like take the skyline on at the lights... You need a diff conversion to the 1.8L - around $1500 minimum with LSD. You'll need a Clutch for this obviously too.
So how much do you want to spend on other things? You will be supplying enough fuel for a sh!tload of horsies, how many do you want to rope in? Personally I think the 255L/h pump is overkill, and on the stock computer wouldn't idle (I know you are running Wolf - just saying), if you want 10 or less PSI the 190l/h pump would have been enough.
You will need a BOV also... I believe that a recirculating BOV is the only LEGAL option, although it might just be QLD, but you can get plenty of the vent to atmosphere ones on eBay. You can get a recirc BOV from a turbo RX7 for around $25, and they will work up to about 12-14PSI.
I'm not sure if the Wolf has anything integrated, but put a wideband O2 sensor on your list. These come with a digital Air/Fuel ratio readout, and are paramount for ensuring safety in your tune. Any time you get the car dynoed they will check your a/f ratios, but if something goes pearshaped in between, you will want to know about it before your engine blows up.
You can get away with a decent air fuel gauge on the stock narrow band O2 sensor, but a wideband is much better.
If you haven't read
this pagefrom start to finish, do it now. And then again, and again.
http://www.miataturbo.net/forums/showthread.php?t=4288Happy boosting. I wish I was with you.
Boags
