Power dip when cold...
Li7hium
Postby Li7hium » Tue Feb 13, 2007 11:02 am
Hey guys,
I've started noticing more and more a significant power dip when I am accelerating on a cold or cool start. Idle is fine and moving around at slow speed is fine, but as soon as I start pushing about 50% throttle or so, it feels like someone has just turned the air con on, with the power dip and it takes a few seconds, and backing off the throttle, to get it to come back on full power.
And NO, the a/c is NOT on at the time.
Any ideas?
Matt
NA8
Wakefield 1:14:78 28-6-09! Oran Park GP 1:27:73 30-03-08 Oran Park South 54:50 14-10-2007 Eastern Creek 2:02:44 6-8-07
BRZ
Pheasant Wood 1:05.4940
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Tue Feb 13, 2007 11:22 am
i have the same thing but it has always been like that. when it warms up its fine (about a minute of normal driving). Maybe the ecu is retarding the timing until it gets to a certain temp for some reason.
StanTheMan
Postby StanTheMan » Tue Feb 13, 2007 11:55 am
I'd be looking at the O2 sensor.
Boags
Postby Boags » Tue Feb 13, 2007 1:25 pm
Sounds like leads to me... How old are they?
Boags
Li7hium
Postby Li7hium » Tue Feb 13, 2007 1:27 pm
Leads are about 90K kms old, as it turns out.
And before anyone asks, yes the petrol tank is full!
:mrgreen:
Matt
NA8
BRZ
Boags
Postby Boags » Tue Feb 13, 2007 1:37 pm
Li7hium wrote:And before anyone asks, yes the petrol tank is full!
Yep, that would have been my next question... :oops:
sabretooth
Postby sabretooth » Tue Feb 13, 2007 8:09 pm
I'm inclined to think it's the AFM or the TPS. The O2 sensor is not used under acceleration...
Li7hium
Postby Li7hium » Tue Feb 13, 2007 8:10 pm
OK, lets dumb it down for the less mechanically minded, moi included.
AFM?
TPS?
Thanks,
Matt
NA8
BRZ
Boags
Postby Boags » Tue Feb 13, 2007 8:12 pm
Li7hium wrote:OK, lets dumb it down for the less mechanically minded, moi included.
AFM?
TPS?
Thanks,
Matt
AFM = Air Flow Meter
TPS = Throttle Position Sensor
I'd still bet your left nut it's leads. Not mine though. :shock:
Boags
sabretooth
Postby sabretooth » Tue Feb 13, 2007 8:35 pm
Boags has a good point - as leads deteriorate they won't be able to ignite the spark in denser or higher-pressure mixtures.
Do that first.
And a shaken-fist to you lot snubbing us IRC-ers!
Craig
Postby Craig » Tue Feb 13, 2007 8:47 pm
Li7hium wrote:Leads are about 90K kms old, as it turns out
Not a bad effort from a set of Magnacors though! 8)
JBT
Postby JBT » Tue Feb 13, 2007 8:56 pm
....power dip when I am accelerating on a cold or cool start....
That's the symptoms mine had when the leads started to fail.
Li7hium
Postby Li7hium » Wed Feb 14, 2007 10:12 am
Difficult job to replace the leads?
I'm thinking of ordering a replacement set of the Magnacors Blue from Mania and doing it myself.
Matt
NA8
BRZ
Garry
Postby Garry » Wed Feb 14, 2007 10:13 am
Easy job. Just replace them one at a time so that you dont get them mixed up.
Li7hium
Postby Li7hium » Wed Feb 14, 2007 10:14 am
And are the NGK Iridium IX Spark Plugs still the bees knees? Since I am doing leads, for sake of completeness I should probably do plugs as well.
Matt
NA8
BRZ
