I've been looking around the engine to find out where the temp sensor is that sends the signal to the ECU - but I can only find the one on the back of the engine - I thought there were 2 temp sensors (1 for the gauge and 1 for the ECU)
Is there another one somewhere - or does the sensor on the back of the engine do both the gauge and the ECU ??
I've got an NB8A if it makes a difference
Coolant Temp Sensor for ECU Location
- Brett_MX5
"You tried your best and failed miserably,
The lesson is, never try"
-Homer Simpson
-Homer Simpson
- Garry
The ECU temp sensor and fan switch are combined on a sensor at the back of the engine. I'm not sure where the gauge sender is, though I thought it was on the back of the engine somewhere as well
- Brett_MX5
- Russellb
- RIP Nov 2014
The sensor on the back of the Engine is for the ECU and the TEMP gauge
The ECU controls the thermo fan
My ClubmanRebuild
MX5 SE Rally car is HERE
- Garry
- Russellb
- RIP Nov 2014
Temp gauge wire is Violet with a White Stripe
My ClubmanRebuild
- sabretooth
- Vehicle: NA8 - Turbo
The internal temperature gauge has its own single wire sensor.
The temperature sensor that the ECU uses to obtain the coolant temperature is in the back of the head in what looks like a thermostat housing. It's under the coil packs.
Unplugging that will -not- change the internal gauge - it'll just cripple your ECU.
Hidden in shadow to the left is the internal gauge sensor.
The dark green thing closest to the camera is the sensor you want.
