Fuses look ok, has half a tank of fuel, will check the fuel pump and spark in a minute.
Anyone have any ideas
CAS (does it even have one) or an igniter module
It has just over 150,000km's on the clock.
Andrew wrote:jules wrote:Fuel pump?
Jules
Yeah i'm thinking that may be the problem.
Just shorted GND and F/P in the diag connector and i get a click so the realy is working.
How do i tell if the pump is running or not
NMX516 wrote:Could it just be the battery?? I've just had similar problems in my other car, and it turned out the alternator was past its best and not charging the battery properly. It ended in tears by the roadside with a flat battery, waiting for a towtruck for 2.5hrs... Cranking an engine into life is a big drain on the battery compared to what it does while driving.
