I have a complete rear end from a 1.8 - diff, subframe, wishbones, driveshafts, uprights, calipers, shockers.
How do I tell whether it was from an NA or an NB?
I understand that the diff has a different uni mount - how do they each look?
Would the brake disc size indicate this?
Thanks - Gavin Eakins,
NA or NB rear end? How to identify diff
Cheers - Gavin Eakins,
Emerald, Victoria.
Emerald, Victoria.
- Garry
NA has flat lower spring perches, NB spring perches are the same shape as the spring if that makes sense.
NA sway bars have rubber bushes on the wishbones, NB's have ball joints.
Thats 2 differences for you
- Matty
