Ok, just bought a Bosch belt 13A0890 for a change I attempted to do & soon gave up on..
But anyway, this new one has teethe on it & the belt currently on the car doesn't. I've got some photos of other NA6 engines where the belt is mostly the non-toothed version but saw a couple with the teethe so does it matter at all?
NA6 alternator belt (toothed, non-toothed?)
- SuperMazdaKart
- adamjp
The problem is not the toothed part of the belt.
The problem is that the Bosch catalogue consistently lists the WRONG belt for the NA6.
Take back the 13A0890 and ask them for a 13A0915. Tell them that the Bosche catalogue is wrong and so in good faith you mistakenly bought the wrong part.
I could not get an 890 belt on with the engine sitting on an engine stand. You have no hope with it in the car.
Adam
- SuperMazdaKart
- adamjp
- SuperMazdaKart
- Astroboysoup
- SuperMazdaKart
ok, returned both belts. got the 13A0915, which still has teethe & switched the A/C belt. had another look under the bonnet & the a/c belt currently on the car is a 4PK845 (though, didn't see any brand name on it & is made in USA as opposed to the Bosche at the store made in Singapore) so thats what i got. hopefully they're the right ones.
- Astroboysoup
im so confused right now..
the belts in mine are all v belts
the only toothed one is the cam belt.
AustCars.net - It's like Facebook but for cars!
- adamjp
- SuperMazdaKart
- Vehicle: ND - 2
The (teeth) are actually not teeth because they dont engage anything on the pulley. All Vee and Micro Vee (multi ribbed belts) belts are dríven on the side walls of the Vee section. The Teeth are merely cut out sections the manufacturers put there to, yes, help the belts have more flexibility on smaller pullies but also provide a fan like cooling effect to keep both the pullies and the belts cooler for longer life.
The tension you put on a belt wedges it down into the pulley and the wedging affect is what then drives the pullies and belts.
Sorry I sell Belts among other things and have had it dríven into me so many times over the years.
