Changing shift lever boots and shift bushes any hints?
skimad
Postby skimad » Sat Apr 28, 2007 8:23 pm
I changed my oil in an attempt to fix my gearbox sticking after accelerating hard but no go.
So I am thinking that doing the above might help?
Is this very hard to do has anybody got any handy links or how to's they can send?
Thanks as always
SOLD - Red NA - NB wheels, Lock Stewart, fluffy dice
green_comet
Car Detailing Guru
Postby green_comet » Sat Apr 28, 2007 8:41 pm
You might want to change the oil in your gearbox turret while you are at it.. Remove the centre console, and rubber boots (replace if they are split), and pull out the shifter. Pump the old oil out and replace it with some new stuff... Its a pretty easy job, and should help with your problem..
Try these two links, scroll down on the first link.
http://www.miata.net/garage/trans/everything.html
http://www.miata.net/garage/shiftboot.html
Ryan
skimad
Postby skimad » Sat Apr 28, 2007 9:30 pm
Thanks Ryan much appreciated. Ill order them on Monday.
JBT
Postby JBT » Sat Apr 28, 2007 10:44 pm
I doubt that will stop the gearbox \"sticking\" unless the lower boot has disintegrated and fallen into the selectors.
skimad
Postby skimad » Sat Apr 28, 2007 11:19 pm
Yeah it only happens going up hill which i think is odd. If i am going downhill hard it doesn't happen.
I had my hand on 2nd accelerating hard up hill and I could feel it move further towards the read of the car as it accelerated (if that makes sense)
Ill give this a go as its cheaper than a new gearbox.
CT
Postby CT » Sun Apr 29, 2007 9:03 pm
Have you checked you're passenger side engine mount? A busted one will affect shifting and many other things. Very common too.
SuperMazdaKart
Postby SuperMazdaKart » Sun Apr 29, 2007 9:36 pm
crikey, didn't realise the turret oil was meant to be up that much judging from the photo. i'd better get some gear oil then..
SuperMazdaKart
Postby SuperMazdaKart » Sun May 06, 2007 2:10 am
one more question, is the turret oil independant of the gearbox oil? fair bit of difference in price from regular gearbox oil to the synthetic stuff
davamb
Postby davamb » Mon May 07, 2007 11:05 am
And one from me on this topic if I may...
I changed my shift bush over to a new brass one over the weekend (shift much better now), but buggered if I could get the gearknob off, both top and bottom boots are split and knackered and need to be replaced - what's the story, am I just too wimpy?
Cheers, Dave, 1990 NA6
Via est vita.
Richee
Postby Richee » Mon May 07, 2007 11:14 am
davamb wrote:And one from me on this topic if I may...
Is there a grub screw holding it on? If not then yep wimpy it is :mrgreen:
Mazda Tribute - its a boat
meanmx
Postby meanmx » Mon May 07, 2007 5:02 pm
Wimpy....Sorry
Ben
2014 VW Mk7 Golf R
TieNN89
Postby TieNN89 » Sat Feb 16, 2008 3:16 pm
green_comet wrote:You might want to change the oil in your gearbox turret while you are at it.. Remove the centre console, and rubber boots (replace if they are split), and pull out the shifter. Pump the old oil out and replace it with some new stuff... Its a pretty easy job, and should help with your problem..
Ryan
do you put the gearbox oil in there or is it different
and how much do you put in there?
bark
Postby bark » Sat Feb 16, 2008 6:05 pm
Davamb you need to take your gear lever out and take your gear knob off. Then the two gear boot seals need to slide off, moving from the bottom to the top. Add some grease on to your gear lever first as this will help the rubber move. Then to install the new gear boot seals simply grease up the gear stick then slide the two boots down the shaft... I recently replaced mine and this worked well.
JBT
Postby JBT » Sat Feb 16, 2008 6:45 pm
AZNTieN wrote:do you put the gearbox oil in there or is it different
Gerabox oil and very little (less than 100ml)
TieNN89
Postby TieNN89 » Sat Feb 16, 2008 7:10 pm
oh ok sweet
how often should i replace this?
now mmm where can i find something to suck that stuff out
