Page 1 of 2
Changing shift lever boots and shift bushes any hints?
Posted: Sat Apr 28, 2007 8:23 pm
by skimad
I changed my oil in an attempt to fix my gearbox sticking after accelerating hard but no go.
So I am thinking that doing the above might help?
Is this very hard to do has anybody got any handy links or how to's they can send?
Thanks as always
Posted: Sat Apr 28, 2007 8:41 pm
by green_comet
You might want to change the oil in your gearbox turret while you are at it.. Remove the centre console, and rubber boots (replace if they are split), and pull out the shifter. Pump the old oil out and replace it with some new stuff... Its a pretty easy job, and should help with your problem..
Try these two links, scroll down on the first link.
http://www.miata.net/garage/trans/everything.htmlhttp://www.miata.net/garage/shiftboot.htmlRyan
Posted: Sat Apr 28, 2007 9:30 pm
by skimad
Thanks Ryan much appreciated. Ill order them on Monday.
Posted: Sat Apr 28, 2007 10:44 pm
by JBT
I doubt that will stop the gearbox \"sticking\" unless the lower boot has disintegrated and fallen into the selectors.
Posted: Sat Apr 28, 2007 11:19 pm
by skimad
Yeah it only happens going up hill which i think is odd. If i am going downhill hard it doesn't happen.
I had my hand on 2nd accelerating hard up hill and I could feel it move further towards the read of the car as it accelerated (if that makes sense)
Ill give this a go as its cheaper than a new gearbox.
Posted: Sun Apr 29, 2007 9:03 pm
by CT
Have you checked you're passenger side engine mount? A busted one will affect shifting and many other things. Very common too.
Posted: Sun Apr 29, 2007 9:36 pm
by SuperMazdaKart
crikey, didn't realise the turret oil was meant to be up that much judging from the photo. i'd better get some gear oil then..
Posted: Sun May 06, 2007 2:10 am
by SuperMazdaKart
one more question, is the turret oil independant of the gearbox oil? fair bit of difference in price from regular gearbox oil to the synthetic stuff
Posted: Mon May 07, 2007 11:05 am
by davamb
And one from me on this topic if I may...
I changed my shift bush over to a new brass one over the weekend (shift much better now), but buggered if I could get the gearknob off, both top and bottom boots are split and knackered and need to be replaced - what's the story, am I just too wimpy?
Posted: Mon May 07, 2007 11:14 am
by Richee
davamb wrote:And one from me on this topic if I may...
Is there a grub screw holding it on? If not then yep wimpy it is
Posted: Mon May 07, 2007 5:02 pm
by meanmx
Wimpy....Sorry
Ben
Posted: Sat Feb 16, 2008 3:16 pm
by TieNN89
green_comet wrote:You might want to change the oil in your gearbox turret while you are at it.. Remove the centre console, and rubber boots (replace if they are split), and pull out the shifter. Pump the old oil out and replace it with some new stuff... Its a pretty easy job, and should help with your problem..
do you put the gearbox oil in there or is it different
and how much do you put in there?
Posted: Sat Feb 16, 2008 6:05 pm
by bark
Davamb you need to take your gear lever out and take your gear knob off. Then the two gear boot seals need to slide off, moving from the bottom to the top. Add some grease on to your gear lever first as this will help the rubber move. Then to install the new gear boot seals simply grease up the gear stick then slide the two boots down the shaft... I recently replaced mine and this worked well.
Posted: Sat Feb 16, 2008 6:45 pm
by JBT
AZNTieN wrote:do you put the gearbox oil in there or is it different
Gerabox oil and very little (less than 100ml)
Posted: Sat Feb 16, 2008 7:10 pm
by TieNN89
oh ok sweet
how often should i replace this?
now mmm where can i find something to suck that stuff out
