Oil for turbo 5's - what are you using & how's pressure?
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Wed Jun 20, 2007 12:02 pm
A quick question for the aftermarket turbos among us - what oil are you now using, and how's your oil pressure at full operating temp?
I'm using the Castrol oil for 'hot 4's and turbos' - comes in a gold coloured container. I just noticed the other day that my pressure at idle once warm is a bit lower (about the 1 mark) than it used to be pre-turbo (just less than 2) - it is fine at startup, so the oil is thinning a bit when warm (obviously). Pressure when driving is normal - just under 4.
What are others using/getting?
ampz
Postby ampz » Wed Jun 20, 2007 12:55 pm
I have Havoline Semi Synth 15/50 from Big W :D
I get just on or over 2 on idle (depends if AC is on or not) when hot.
It is a lot quieter that it was before (read lifter noise, it sounded like it had a diesel factory option on mine :shock: ).
I was using Magnatec 10/40 before (pre turbo).
I'm very happy with the Havoline, but it is only freshly changed.
PS: It was under $30 too :mrgreen:
Huh?
Juffa
Postby Juffa » Wed Jun 20, 2007 2:41 pm
Mobil 1 - 5w-50
Just below 2 when on idle, around 6 at higher revs before completely warmed up and closer to 4 once warmed up.
Not burning any oil and it seems to be staying pretty clean between changes. I try and buy the oil when super cheap is having a sale.
J
Boags
Postby Boags » Wed Jun 20, 2007 4:54 pm
Motul Turbo-Light (which they don't make anymore... :evil: )
I have the same characteristics as you UA. :D
Boags
GS
Postby GS » Wed Jun 20, 2007 9:30 pm
Likewise, im using Motul Turbo light and getting similar results. When warmed up it idles in the 1's (slightly lower than pre turbo) and is up around 4 in general driving.
1989 NA6
Sean
Postby Sean » Fri Jun 22, 2007 12:05 am
I've been using turbolight cause I had a stash of it, butfound low pressure at low RPM/idle too.
I have moved the shell synthetic stuff (cant remeber name) and all is well, just below 2 once warm.
sabretooth
Postby sabretooth » Fri Jun 22, 2007 5:49 pm
Shell Helix Ultra. Cold the pressure is at 4kg/cm2, and warm it's at 1.9-2.5.
Sean
Postby Sean » Fri Jun 22, 2007 7:04 pm
sabretooth wrote:Shell Helix Ultra. Cold the pressure is at 4kg/cm2, and warm it's at 1.9-2.5.
Yeah I think that's the stuff I'm using now.
