stock 5 speed power handling
- 16bit
Does anyone have a rough figure of how much the stock 5speed box from an nb8a can handle? Or is it a case of driver style and condition of the box?
Both Ian and Les's NA6's are making around 200kw.
Les's 17 year old box is still fine.
Ian's is more of a race car with an aggressive diff and he finally broke his 17 year old gear box this year.
His Kaaz diff didn't last any where near as long.
Sheck wrote:depends how you drive it, i broke 2 5speeds at about 140rwhp, one only lasted one drift event, the other a couple.
6 speed is copeing well so far @150hp soon to be more..
Dave
is it difficult to switch 6/5 speeds between cars (e.g. are the mounts similar?)
NB8A
Blue94t wrote:I popped 5th gear with around 160rwkw.
That was a full throttle roll on from 80kmh - bang. Pulled out to overtake a truck.
Accelerating hard in 5th to overtake can cause that even with probably half that power.
- Fuzzlet
I've nearly destroyed 3rd gear in my 5spd....apparently the 6spd from an SE has stronger gears
Users browsing this forum: No registered users and 17 guests
