How to remove driveshafts from NA diff?
gavin_eakins
Postby gavin_eakins » Thu Jul 05, 2007 1:06 pm
Folks,
I have the diff from a 1.8 on the bench, with driveshafts.
It does *not* have the bolt-on inner CV joints of the earliest models.
How do I remove the driveshafts?
Gavin.
Cheers - Gavin Eakins,
Emerald, Victoria.
StanTheMan
Postby StanTheMan » Thu Jul 05, 2007 1:11 pm
Get a strong screwdriver.
pace it against the drive shaft in the outward direction
& whack the sh*t out of it.
it will pop out.
doesn't have to be a screwdriver. strong piece of wood will do it too. but more force will be absorbed.
gavin_eakins
Postby gavin_eakins » Thu Jul 05, 2007 1:18 pm
Thanks, Stan.
I tried prying it against the diff case, but since it seemed to be restrained, I presumed it some sort of circlip & gave up.
I guess the \"wack the sh*t out of it\" technique just overcomes any existing clip?
Gavin.
Emerald, Victoria.
StanTheMan
Postby StanTheMan » Thu Jul 05, 2007 1:19 pm
sure does
It will need a good whack. Don't be shy
Grumpy
Postby Grumpy » Thu Jul 05, 2007 9:23 pm
2 small purpose made timber wedges work fine.
Sadly MX5 less for a while.
Rebuilding an 89 Honda CRX
gavin_eakins
Postby gavin_eakins » Fri Jul 06, 2007 3:55 pm
Thanks, blokes for the advise.
They really just needed some \"oomph\" on the lever, and there they were.
Gavin.
Emerald, Victoria.
