turbo kits
Alex
Postby Alex » Fri Jul 13, 2007 4:16 pm
buy the kit and DIY, i'm sure some forum members won't mind helping you put it in
stevesports
Re: turbo kits
Postby stevesports » Fri Jul 13, 2007 4:40 pm
megamoose_69 wrote:hey guys im looking to upgrade my na mx5 to a turbo i've desided to go a stage 2 set up, i was just wondering if anyone knows of some reliable places. i've found a couple of places. but i've had some problems in the past going to places i haven't heard of before. can anyone help
p.s i live in the brisbane area
what is a stage 2 set up?
anyhoo, maybe grab the AVO setup and DIY? I remember AVO has a DIY guide on their website, if not give them a call.
lowmiata
Postby lowmiata » Fri Jul 13, 2007 5:17 pm
What is your budget and what do you wish to get out of your car?
DIY would be my prefered option but I have done it a few times now!
Paying some one is alays easier but you don't get the same finish
If you get the avo stg 2 kit
mostly all of it is bolt on
or you can drop a few parts like i did and look after those parts elseware
(makes overall cost cheaper and you get better spec'd items)
look after fuel managment elsware as well and you will make a bit of a saving there as well
don't skimp on the important parts as a general rule and you'll be right
here are some I have prepared earlier!
S14 200sx Front mount intercooler piping & fitting of exhaust manifold
Same again but without the manifold just FMIC and pipework
180sx again FMIC and pipe work
Toyota surf with TMIC and pipework
uncle arthurs pfft red car!
FMIC piping fitting ebay manifold and exhaust
here is my original write up on sabretooths website
http://forums.sabretooth.id.au/viewtopic.php?t=46
this is a newer ic of mine
there is also Geoffs turbo piping
Countless more SR ones in other cars
pulsars etc
If you know what you are doing they are quite easyto do!
EVI15 1998 to 2008
lowmiata
Postby lowmiata » Fri Jul 13, 2007 5:25 pm
megamoose_69 wrote:the stage 2 kit is just you basic kit with an aftermarket ECU and someother goodies.
well in saying i should do it my self what tools would i need, and how difficult is it?
If you have a decent spanner set, screw drivers soccets etc you will be half way there!
tools that you would need that you probably wouldn't have?
there would probably be one or two but none come to mind.
you could pic them up as needed to.
difficulty?
depends on what you buy and how you do it
but by far the hardest part would be like the pictures above, mounting and plumbing the intercooler this requires special tools etc for fabrication.
I would steer away from the ebay manifolds as my experience is they are not "bolt on"!
SMB or AVO make good manifolds
I bought my turbo, manifold and lubrication line from avo and did the rest myself
to break it down
AVO cost was about 2600
intercooler and piping 700
Microtech 1800 fitted and tuned etc
and there would be another 1500 or so i think in other bits and pieces
i did have a break down of costs some where on the forum but it will probably be hard to find
you are quite welcome to look at mine and see whats needed before attempting it if needed
Regards,
Ryan.
EVI15 1998 to 2008
lowmiata
Postby lowmiata » Fri Jul 13, 2007 5:59 pm
http://www.avoturboworld.com/news/miata_a4_small.pdf
pretty sure stage 1 is about 5500 and stage 2 is just shy of7000
The N power stuff
It would get you turbo charged but with limited ability for progression later on
and with a TDo5 turbo
look at AVO and you are starting with a T25 (bigger) and much more user friendly when upgrade time comes as they are used in the SR area and are common as well just common
the exhaust manifold shown in the picture is the same as uncle arthurs, his did defiantly NOT fit and unless you have the right tools you would be stuck!
and that kit is not intercooled.
My advice?
Start looking at ebay for
Intercooler
injectors
bov
maybe a turbo
AVO manifold can be had for about 700 + dump pipe which was roughly 250
turbo's can be 'clocked to suit aplication so most T25/28's can be used
fuel managment is personal choice but could be done for approx 1500 look at wolf 3D etc
something like this is a start
http://cgi.ebay.com.au/NEW-Rebuilt-GARR ... dZViewItem
intercooler
http://cgi.ebay.com.au/SKRacing-FMIC-TU ... dZViewItem
avo website is
give them a ring and see how much the parts will set you back to get started
Regards,
Ryno
EVI15 1998 to 2008
ampz
Postby ampz » Sat Jul 14, 2007 3:18 pm
It sounds like you want to get stuck into another build LM :lol:
Huh?
lowmiata
Postby lowmiata » Sat Jul 14, 2007 5:28 pm
ampz wrote:It sounds like you want to get stuck into another build LM :lol:
There is three weeks till we move into "OUR HOUSE"
From Day 1 Dr evils shop will be open for business
(after I lay 7 cubic metres of concrete and get my water tanks installed!)
Cant wait to have free reign and do anything I want on my property!
EVI15 1998 to 2008
mossy
Postby mossy » Sat Jul 14, 2007 10:22 pm
Why don't you just buy one already installed :mrgreen: http://www.aus-cartalk.com/viewtopic.php?t=24998
Users browsing this forum: No registered users and 17 guests
