The NB doesn't have an AFM, are you talking about the MAF or are you a little confused?
Can anyone clarify that the NB will still run if you unplug the MAF?
Roodosutaa wrote:My bad... wasn't aware there was a distinction. Yes technically it's a hotwire mass air flow sensor.
Roodosutaa wrote:Checked out the big forum, took the MAF sensor out for a physical check, no damage, then got out some electronic contact cleaner and sprayed a bit on the electrode/hotwire thingy
