Replacing Top Control Arm Bush
- Hot Rodders
The left rear tyre has scrubbed badly on the inside and the culpritt seems to be the Top Control Arm Bush. Can any one shed some light on how difficult to replace and how expensive. Could this be done via a Dodgy Day?
Where I had the car serviced, they said that this was the third one they had seen. Is this common!
Advice would be appreciated.
Cheers!
Rod.
Cheers!
Rod.
How many Ks has she done?
I would suggest that if you are going to replace one you should do the lot. N*Power has the set for $450
http://www.nahux.com/NPOWER/vehicle_pro ... d=2&cid=49
I have fitted two full sets myself, and I'm willing to assist with the install.
The Vic club has specific install equipment that will help.
Did someone say Dodgy Day?
Rod, it's about 2 hours to jack up car, remove wheel, disconnect swaybar, release outer upper control arm bolt, undo and extract the bolts through the inner upper control arm bushes, spin the arm around, squeeze out bushes, fit new bushes, reassemble. Tools needed must include a bush remover - add about 4 hours if you can't find something decent to do that bit.
You'd have to ask why you have just one bush failure. Investigation of the condition of the rest is warranted. Full replacement is around 10 hours in a workshop ... or 2 years of your life at home.
- Hot Rodders
- Hot Rodders
Juffa wrote:How many Ks has she done?
Did someone say Dodgy Day?![]()
Juffa, how does one aquire a loan of the said equiptment from the Vic club?
Check with President Murray, or President of Vice, Al. One of them should know who has said equipment.
There are links to their email addresses on the Club website or try their after hours phone numbers in the Club mag.
J
- Hot Rodders
J
- Matty
- Hot Rodders
- fastfreddygassit
- Waitin' for a mate
- Hot Rodders
- fastfreddygassit
Hot Rodders wrote:Thanks Freddy. You have a PM
no I don't
send it again.....or we'll chat on Thursday night.
- Hot Rodders
