Silicone Hose sizes
Ajay
Silicone Hose sizes
Postby Ajay » Sun Oct 07, 2007 4:04 pm
Hey Guys..
im buying some silicone hose lengths to do such pipes as the radiator overflow pipes/oil breather pipe Etc basically every blue hose in the photo below of mx5maniac's sexy car (see pic below), however i will be getting YELLOW (no suprise there)
does anyone know what thickness hoses i will need to do all these..
i have found a set with 4mm 6mm and 8mm hoses....and another set has 4mm 6mm and 10mm hoses
your help is always appreciated
Ajay
Ajay
Postby Ajay » Mon Oct 08, 2007 2:28 pm
can anyone help me?
trader
Postby trader » Tue Oct 09, 2007 6:52 pm
Can't really help you there mate, but you can clean the engine bay up a bit by putting the cannister under the wheel arch and moving the wiring loom behind the overflow container, washer reservoir to in front of radiator. No holes need to be drilled and it gets rid of that spagetti look - a good weekend job! If you have air horns put the compressor where the washer bottle is and run the tube around under the guard lip.
NB SE, NA 1.8.
Ajay
Postby Ajay » Tue Oct 09, 2007 9:51 pm
well thats not my engine bay.. but i would really like a similar design to steves..
Fra66L
Postby Fra66L » Wed Oct 17, 2007 8:26 pm
Did we get any answers?
T
The Green Meanie - Grace Green NB8A
Veilside - It's Japanese for UGRY!
Ajay
Postby Ajay » Sat Oct 20, 2007 8:43 pm
maaaaattte!.. i found what i need and will post pics.. my engine bay is finally finished but yes even without anyone on here knowing i was still able to find out
AJay
