Hi
I recently did mechanic work on my 90 roadster. (The diff had to be replaced)
we removed the exhaust which included the cat converter. I however have lost the O2 sensor. I cant see any problems with the Car, IE running rich or lean or using extra fuel. The only problem is a funny idle at cold start which clears up. Goes from 800 to 1200 rpm.
Do i need to find another O2 sensor and replace it?
Thanks
O2 Sensor on NA6
- corners
- Vehicle: ND - Supercharged
- jules
- Guitar Hero
- AJ
jcs86 wrote:So should I get another cat Converter and O2 sensor?
I've been told by most that you dont need a cat but might need to O2 sensor???
if Mr Plod or the RTA finds out you aren't running a cat you'll be in bucketloads of trouble mate........LOL
XMX5 Rogues
- Ajay
- corners
mx5_boy wrote:isnt tampering with a cat a sever criminal offense?.. a friend of a friend of a friend of mine used a run a little charade with a hollowed out cat and it used to shoot metre long flames out the back lol
I am aware of the QLD Fines etc but am more concerned about whether i need one for the engine. I will look at getting an O2 sensor as I know the engine relies on them for its air/fuel ratio
- Sean
jcs86 wrote:Just curious regarding this.
The sensor I removed was the one after that cat converter. Do I need to replace this?
the one in the headers is still there untouched.
You should replace the cat...
Reason?
We all need to breathe.
If it's the one just after the cat - that's a temperature probe AFAIK, and doesn't affect your engine performance.
- corners
Curly wrote:If it's the one just after the cat - that's a temperature probe AFAIK, and doesn't affect your engine performance.
Ah ok
Sweet. Maybe just removing the Cat has made it run more rich.
