engine issue
Ajay
Postby Ajay » Sat Oct 20, 2007 4:15 pm
i think you are referring to the \"short nose crank\" problem.. i personally dont know much about it but see here
http://www.miata.net/garage/crankshaft.html
i think the problem was corrected mid 91 as i have a December 91 and i dont have the short nose crank
Ajay
corners
Vehicle: ND - Supercharged
Postby corners » Sat Oct 20, 2007 5:34 pm
I bought my car as in import and the problem occured to me. My car is a 90 model.
Boags
Postby Boags » Sat Oct 20, 2007 6:19 pm
If it is a \"short nose crank\" it is possible the problem will occur. It only happens if you stuff up the reassembly when changing the front main seal.
Easy way to tell a short nose from a long nose (which is different to a big nose) is to count the numbers of holes on the pulley (the crank pulley: central and down the bottom). If it has 4 holes (89-mid 91) you have the short nose. If it has 8 holes (mid 91-late 93) you have a long nose. The later model 1.6L engines (which never came out here in Aus) had big nose cranks IIRC.
Boags :D
Craig
Postby Craig » Sat Oct 20, 2007 6:55 pm
Meh...just get the 1.8 NA sold from late 93 through to 97! :mrgreen:
Problem solved! :P
Matty
Postby Matty » Sat Oct 20, 2007 7:18 pm
Craig wrote:Meh...just get the 1.8 NA sold from late 93 through to 97! :mrgreen:
Problem solved! :P
Big nose 1.6s and even 1.8s have had crank keyway failures. Much rarer than the small nose 1.6s though.
(mine broke)
timk
Postby timk » Sun Oct 21, 2007 5:28 pm
My car has 260,000km on it now and I just replaced the front main oil seal. As part of this I bought a new bolt and woodruff key, then used some Loctite and torqued it properly. The keyway looked as good as new, so I think it is only if someone touches that bolt that you have to worry. I think the yanks make the problem out to be much bigger than it really is (or they have more dodgy mechanics over there).
meanmx
Postby meanmx » Sun Oct 21, 2007 7:16 pm
I have a short nose crank and mine is fine. I get the feeling that more people have no issues rather than have problems.
Ben
2014 VW Mk7 Golf R
adamjp
Postby adamjp » Sun Oct 21, 2007 10:38 pm
x2
Adam
