Maruha VVT F-camshaft
AB7
Postby AB7 » Tue Oct 23, 2007 3:48 pm
AB7
Postby AB7 » Wed Oct 24, 2007 12:53 pm
Does anyone here had aftermarket cams on their NB8B VVT?
Apparently this Maruha Unit, doesnt require ECU tuning...
hamish71
Postby hamish71 » Fri Nov 09, 2007 11:46 am
No, but I am keen to keep this post alive and see what else people know about cams for vvt.
hamish71
Postby hamish71 » Thu Jan 10, 2008 7:15 am
the maruha website in japan, translated poorly into english seems to indicate that it is NOT for VVT?
http://www.maruhamotors.co.jp/miata/
AB7
Postby AB7 » Thu Jan 10, 2008 11:50 am
Hei Hamish,
They do actually have cams for VVT from Tomei/ Maruha
I was thinking of getting them about 1.5 months ago from Chikara Motorsport.
They have one second hand set of 2001 NB for around $900.00 delivered.
Email him if you are interested and let him know that 'Andy from Melbourne' told you. Here's his email: chikara_motor@hotmail.com
With The Maruha VVT cam you will need to replace the lifter kit because the cam base is 33mm, and stock is 36mm. If you want the cheaper way to install the Maruha cam, you can just add the undershim between the valve head and your stock lifter bottom. Just make sure the valve clearance is IN 0.2mm and EX 0.25mm.
They also have another second hand set of Maruha ITB system with Freedom ECU.
http://www.chikaramotorsports.com/catal ... t=1&page=2
This one off another 2001 NB and already tuned by Chikara Motorsport. I was quoted by him for $3.2 K inc shipping to Melbourne. I reckon its a pretty good deal for Maruha Kit but with one problem. Freedom ECU is in Japanese, I don't know anyone in Melb that can tune it.
